LinkBack (1) | Thread Tools |
#1
94 GT
going to the track soon!!
any tips its gona be my first time
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
street tires? launch at 1500-2000 rpms and shift quickly
sticky tires? launch at 2500-4500 rpms and shift quickly If you blow anything up, pull to the side, don't oil down the track... Good luck.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
94 GT
when i launch i should only let it out fast enough so that it doesnt bog down right?
drop the hammer and floor it at the same time. If it bogs, next time add 500 rpms to your launch rpm. If it spins, subtract 500 rpms. Don't get excited to cut a good reaction time, take your time. Find the optimum launch rpm where it doesn't bog and doesn't spin. Some cars are more sensitive the the rpm they like to launch at and it takes awhile to find the sweet spot.
94 GT
awsome thanx
1982 GT t-top
no proof of purchase
if you dont know how to stage figure it out before your there although you probably do and no john force burnouts
dont burnout with treaded tires.
2008 Hammock Rodeo Champ
i have no mustang. so don't listen to anything i say. |
94 GT
really???? i thought even with street tires you could get them sticky a little, should i let out some air pressure?
My Stallion is Bigger!
When you pull up to the staging lanes if your on streets tires drive AROUND the burnout box and spin the tires a few times when you get around it to knock the dirt off. If you run treaded tires through the burnout box water will get up in the tread valleys and your tires will carry this down the track as you go making it more slick and making you look like a jackass for ruining the traction in that lane. When you stage you will ease up to the line till the little yellow light at the top lights. once you are pre staged inch forward until the second light illuminates and as soon as the second comes on get ready to go because there will not be a great amount of time. If you are running a manual tranny I always dump the clutch and go on the last yellow coming down the tree. This will give you a very good RT(Reaction Time) As for RPMs, I have to leave at 1900 on street tires if I dump the clutch. Most usually I pedal the clutch a bit to keep the rpm's up and the bogging down so I can launch a little closer to 2500 RPM's Just make sure you give your car a real good once over before you get to the strip and HAVE FUN!
make sure your car will pass inspection also.
They check your car before you can race. It must pass inspection.
1989 mustang GT 5.0
I always do burnouts with all tires. Especially street tires. Just only burnout untill they just start to smoke and then stage.
A lot of people perpetuate the untrue rumor that burnouts on street tires are bad. But everyone I know that cuts 1.7-1.8 60 foots on true street rubber does a burnout, myself included. And yes, I use the water box and no there is no water left on the tires after doing a proper burnout.
1988 lx
9.68@142
hard rubber=not sticky
soft rubber=stickey cold rubber=hard rubber warm rubber=soft rubber can you do the math???
Just make sure you pull all the way out of the water box during your burnout and then do at least a 3 second burnout after you are all the way out of the water to clear the water off the tires.
I usually use first gear and hold it at 6,000 rpms for a good 3-5 seconds.
#15 | |
1988 lx
9.68@142
james has some 275 nitto's on his car with a pretty much bone stock mustang and he still spins off the line.
#17 | |
1992 Lx
11.39@119.24
yeah but hes hung! i think i need to drop the psi more these fn 3.27s arent helping in the 60' area
You can cut a 1.8-1.9 60 foot in a bone stock mustang with 225 all season tires...with all 225 hp...but not without warming the tires.
BTW launching a bone stock mustang at 5000 rpms and sticky tires is how you get the best times out of them.
94 GT
what about the tire pressure does it help if you let some air out?
20-25 PSI on regular radials.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/75276-going-track-soon.html
| going to the track soon!! | This thread | Refback | June 11th, 2008 11:26 AM | |
Threads Similar to: going to the track soon!!
| Going To The Track... | oh2swapped | 99-04 | 3 | April 10th, 2008 04:50 PM |
| Went to the Track | Humdesnuts | 99-04 | 7 | April 7th, 2008 08:35 AM |
| track on LI | midnightrace | Modular Mustangs | 0 | March 12th, 2007 08:18 PM |
| Going to the track...need help! | CMSchoff | V6 Mustangs | 8 | August 20th, 2006 04:46 PM |
| To The Track I Go. | einod | V6 Mustangs | 15 | August 18th, 2006 05:04 PM |
