electric fans
Old June 11th, 2008, 01:17 AM   #1
mxnate116's Avatar
88 mustang GT
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
electric fans
so i have two electric fans running on my car and ive come to notice its pulling alot of power. and its straining the hell out of the alternator. more then it should as its a 130A alternator. thats just idling with my stereo off and no lights or other acc on.
i have the fans wired in series and im thinking that might be why if i wire them in parallel could it change how much power they pull?
i know if you wire speakers in parallel it increases resistance, and series lowers resistance but does it change how much power its running?
Old June 11th, 2008, 01:21 AM   #2
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
parallel it you are correct
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old June 11th, 2008, 01:31 AM   #3
mxnate116's Avatar
88 mustang GT
sweet thanks man
Old June 11th, 2008, 01:37 AM   #4
chickenbot's Avatar
1990 mustang gt
eventually
i knew that ee major would help some day
1990 gt 5.0
3.55 gears
Old June 11th, 2008, 01:40 AM   #5
mxnate116's Avatar
88 mustang GT
haha oh it did big time
Old June 11th, 2008, 02:26 PM   #6
ryans88gt's Avatar
in parallel they will draw more current. lower resistance = higher current draw at the same voltage.
With that said, they should be wired in parallel anyway or they are both performing poorly because you will have a big voltage drop.
Old June 11th, 2008, 03:22 PM   #7
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
get a smaller pully on that altornator
<font size=4><b>MILITARY CREW
Old June 12th, 2008, 12:01 AM   #8
mxnate116's Avatar
88 mustang GT
i might have to cause the pulley is pretty massive that came with it.
also does anyone know where i can get a smog pump delete bracket at cause the belt routing isnt working. if i go to a smaller pulley on the alt the belt would prob rub itself.
Threads Similar to: electric fans
Electric Fans... DIRTYD 5.0 Mustangs 12 December 22nd, 2007 09:40 PM
eLECTRIC faNS javier351lx 5.0 Mustangs 30 September 13th, 2007 10:03 PM
Electric Fans javier351lx 5.0 Mustangs 15 July 15th, 2007 03:10 PM
Which temp setting for electric fans? 8A_Honda 5.0 Mustangs 4 April 22nd, 2007 09:55 PM
