351W casting numbers - Forums at Modded Mustangs
post #1 of 8 Old June 14th, 2008, 10:43 PM Thread Starter
I am trying to decode my 351W block and I cannot find any info on the casting #'s. I was wandering if anyone could help me out. This is the number behind the starter E6AE-6015-BA The second letter 6 could be a G, it was hard to tell. Any help is appreciated, THANKS
92sspnotchback is offline
post #2 of 8 Old June 14th, 2008, 10:57 PM
the second digit is a 6
youre motor is an 86 i do believe
B-1950-59
C-1960-69
D-1970-79
E-1980-89
F-1990-99
the second diget is the year in the decade your motor was made in. the 'A' after the 6 means it just comes from a ford (not a ford truck, mustang, falcon, and so on) and the E stands for the engine group. 6015 is just the basic part number. and the BA is the revision of the part (in your case the motor). if A was the first letter, it would be the original part, B is the first revision, C would be the second revision and so on and so on.
i hope this helps, let me know if theres anything i need to re-explain
83fox is offline
post #3 of 8 Old June 14th, 2008, 11:03 PM
all motor
SALIV8's Avatar
PART NUMBER DECODE
First Character
Year
C=1960
D=1970
E=1980
F=1990
etc.
Second Character
Year in the decade
Third Character
Car line
A=Full size/Galaxy
B=Bronco (70-75)
C=Torino/Elite
D=Falcon (60-69)
F=Outside US
G=Comet (61-68)
Montego (69-76)
H=Med./Heavy Truck
J=Industrial
L=Lincoln(58-60)
M=Mercury
O=Fairlane (62-68)
Torino (69-76)
R=Capri
S=Thunderbird
T=Truck
U=Lincoln(61-up)
V=Lincoln
W=Cougar
Z=Mustang
HM=Holman-Moody
3A635=P/S kit
4000--4599=Rear axle
4600-4999=Driveshaft
5000-5199=Frame
5200-5299=Muffler
5300-5399=Front springs
5310=Spring chart
5400-5999=Stabilizers
6000-9999=Engine ID tag/pulley ID chart
6900-7999=Manual trans-exc. linkage
7000-7299=Manual trans linkage, etc
7300-7499=Manual trans linkage, etc
7500-7999=Clutch
7000-7999=Auto trans - exc. linkage
7000-7199=Auto trans linkage, cooling, etc
7200-7399=Auto trans linkage, etc
7400-7999=Auto trans linkage, etc
8000-8499=Radiator, grill, cooling
8500-8599=Water pump
8600-8999=Fan
8620=Drive belt chart
9000-9299=Fuel tank & lines
9300-9399=Fuel pump, gauge
Forth Character
Series code
A=Chassis
B=Body
E=Engine
M=Motorsports
X=Muscle Parts
Y=Lincoln/Mercury
Z=Ford Parts & Service
9400-9499=Manifolds, t-stat, emission
9500-9599=Carburetor
9500-9999=Carb parts/lists
9600-9699=Air cleaner and related
9700-9999=Choke, accelerator, speed control
10300-10599=Alternator, pulleys, mounting
10600-10999=Battery, instrument cluster
11000-11999=Starter, ignition, headlamp sw
12001-12999=Coil, distributor, plugs
13000-13999=Headlamps, parking ,turn ind.
SALIV8 is offline
post #4 of 8 Old June 14th, 2008, 11:49 PM Thread Starter
THANKS,guys. is that a good block? Does it have provisions for roller cam?
post #5 of 8 Old June 15th, 2008, 12:37 AM
Roller cam 351W blocks started in '94
and will have F4TE serial number.
Can still use roller cam, just have to use the expensive
linked bar lifters.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
r.barn is offline
post #6 of 8 Old June 15th, 2008, 12:40 AM
yeah aint they something like 6-700 bucks for a set of them?
i wouldnt think its really worth it, you can still make good power with a flat tappet cam
83fox is offline
post #7 of 8 Old June 15th, 2008, 12:59 AM
ryans88gt's Avatar
$500 a set, for that price, solid rollers look really nice.
ryans88gt is offline
post #8 of 8 Old June 15th, 2008, 01:29 AM
I think you can get a decent set for more $400-500
You'll end paying that much extra for a roller cam block cause they
are so sought after anyway ...... kind of a 6 up or half dozen down thing.
God Help Us
r.barn is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/75867-351w-casting-numbers.html
engine sin - Canadian Rodder Hot Rod Community Forum This thread Refback November 26th, 2013 10:54 AM
engine sin - Canadian Rodder Hot Rod Community Forum This thread Refback October 29th, 2013 03:19 PM
engine sin - Canadian Rodder Hot Rod Community Forum This thread Refback October 28th, 2013 10:34 PM
engine sin - Canadian Rodder Hot Rod Community Forum This thread Refback October 28th, 2013 10:26 PM
351W Block Numbers This thread Refback April 20th, 2013 12:00 PM
Might buy a 351w + auto trans from a 79 t-bird ($100) - MustangForums.com This thread Refback April 20th, 2011 06:30 PM
Ferðaklúbburinn 4x4 • Skoða umræðu - 351 cid This thread Refback December 30th, 2009 06:08 PM
Ferðaklúbburinn 4x4 • Skoða umræðu - 351 cid This thread Refback June 20th, 2009 08:39 AM
Ferðaklúbburinn 4x4 • Skoða umræðu - 351 cid This thread Refback June 15th, 2009 12:16 PM
Ferðaklúbburinn 4x4 • Skoða umræðu - 351 cid This thread Refback June 14th, 2009 06:04 PM
