LinkBack (1) | Thread Tools |
#1
MSD
i purchased an 84 5.0 with a MSD in it, however there are a couple of wires not attached and the tac doesn't work. Does anyone have a copy of the wireing diagram for these things. Thanks
1989 Mustang LX
10.98@126.7 NA
Which MSD? The diagrams are available at their web site.
Never fast enough.
it is a 1600 series, not sure what the &^$% that means, and can't find the wireing on the website.
thanks |
91 LX 5.0
11.87
1989 Mustang LX
10.98@126.7 NA
I guess the first thing is can you locate a part #. Second thing is what ignition control are you using. Most of the MSD distributors only work properly with MSD control modules.
Never fast enough.
Can you take a picture of the distributor and ignition box? Are you running a MSD box also?
I have no idea what a 1,600 is. I have several of the MSD-8352, MSD-8379, MSD-85805, MSD-85842 and a few of the MSD-8382. Try to find a part number that resembles one of these and you will probably get more help than you need.
You haven't failed until you stop trying. |
it is a 6200 series msd. there are 8 wires The electrical system is stock. stock coil, stock distributer.
1989 Mustang LX
10.98@126.7 NA
http://www.msdignition.com/pdf/6%20series/6series.pdf Depending on your tach, you may need an adapter. I'm using one on a 6AL with an Auto Gauge tach.
Never fast enough.
That one doesn't have an output tach terminal? I always use a spade connector to the after market tach's of course along with the power/ground wire to the proper sources.
If you are trying to wire it into the factory tach then I can give ya the wire color that feeds the factory tach. Or you can do it the right/easy way and get the adapter. I do know that it is in the harness on the drivers side crammed in the corner closest to the wiper motor. I have done this several times but can't remember the color of the wires.
so you are saying just tie the tach pulse wire into the msd unit at the tach output terminal with a spade connector? Yes i would like to use the factory tach for this application. After looking at the different set-ups, i guess the guy who installed it did it properly, I just have no idea why the white wire is not to be used.
#11 | |
1989 Mustang LX
10.98@126.7 NA
Never fast enough.
yes it does!.
![]() I have done worse things than that.
1989 Mustang LX
10.98@126.7 NA
We all have. Anyone who says different is a liar. LOL
Never fast enough.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/76052-msd.html
| MSD | This thread | Refback | June 25th, 2008 08:39 AM | |
Threads Similar to: MSD
| msd help | mjkids | 99-04 | 2 | November 2nd, 2007 05:51 PM |
| msd | terribleonexx88 | 5.0 Mustangs | 9 | October 11th, 2007 09:07 PM |
| MSD IGNITION | mightyb28 | 99-04 | 5 | March 16th, 2007 07:12 PM |
| MSD IGNITION | mightyb28 | General Tech | 2 | March 13th, 2007 08:27 PM |
| MSD? | 00RoushV6 | V6 Mustangs | 2 | February 20th, 2007 04:04 PM |
