Discussing Power Gains??? in the 5.0 Mustangs Forum. On a stock 302 block if I were to put on 351w heads (ported with ...
Old June 16th, 2008, 02:16 PM   #1
Power Gains???
On a stock 302 block if I were to put on 351w heads (ported with a valve job), 1.6 roller rockers, Trickflow stage one cam, cobra intake and long tubes what kind of power do you think that I would gain and maybe even put to the ground. I also am installing a NOS 5115 kit.
Old June 16th, 2008, 02:25 PM   #2
dr.gonzo's Avatar
everything besides nos, mabey 25-30 hp. I wouldnt waste the time or money by just going with 351 heads.
FREE LUNCH, FINAL
WISDOM, TOTAL COVERAGE... WHY NOT?
Old June 16th, 2008, 03:28 PM   #3
They are free goodies.
Old June 16th, 2008, 04:21 PM   #4
what year windsor heads are they? cause if there not from 1974 or earlier, there almost worthless power wise (dont quote me on that year exactly) From my understanding the best windsor heads to have are the DOOE heads, and even then I believe a set of iron gt-40 heads outflow those windsor's.
Old June 18th, 2008, 01:48 AM   #5
351 heads will lower ur comp ration, they flow better but they will lower ur comp so ull prolly gain all top end power
Old June 18th, 2008, 01:54 AM   #6
e3sean's Avatar
1988 lx 5.7
11.6@109
even thought they are free you are going to spend 100 on gaskets and are they coming off a running motor? if not you are gonna want to get em resurfaced and proly a valve job the seals may be worn out.
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
MILITARY CREW
USAF LUKE AFB AZ,
E-5 SELECT 7995
AMMO I.Y.A.A.Y.A.S
Old June 18th, 2008, 02:22 AM   #7
78mach1's Avatar
if they arent rebuilt and ready to go, your wasting your time.
instead look for some gt-40p heads that you can work over. you will be better off in the long run
In Memory of Nick Goris.
Originally Posted by Darrell View Post
When I shift, there is no RPM drop. I pound gears like Zippee pounds his meat.
Old June 19th, 2008, 03:57 PM   #8
Yes they came off of a running motor with less the 5000 miles on them.
Threads Similar to: Power Gains???
Power Gains From O/R X-Pipe And Lontubes..? LS1KiLLA 2005+ 52 May 5th, 2008 09:53 PM
power gains mustang2517 99-04 6 October 14th, 2007 05:25 AM
difference in power gains mustang2517 99-04 5 October 7th, 2007 07:38 PM
Power Gains Tony_90fox 5.0 Mustangs 20 September 26th, 2006 10:25 PM
wanting some power gains j2000_guy 5.0 Mustangs 11 July 8th, 2006 01:41 PM
