Discussing idle problem. in the 5.0 Mustangs Forum. Hey, my 5.0 has an idle problem, she will idle right around 1k rpms ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
idle problem.
Hey, my 5.0 has an idle problem, she will idle right around 1k rpms when cold, which.. i wish it would be at like 750 because it sounds a lot better (e cam) at low lopey rpms. Before i do heads and an intake manifold i want it to idle right, when the car warms up she idles sometimes at 1300 rpms. always over 1200, sometimes higher than 1300. it sometimes sticks to 1600 for a few seconds, and drops to like 1300 like i said. So this is gay and is a problem and i want my car to idle at 750 like it should so tell me the answer or else.
331s burn oil and have a bad piston to head ratio. http://www.StreetChallenge3D.com/sig...?referal=1BAD1 LOL @ THIS http://www.ihateyoujulia.com/?id=0a8...27aa2c6245e4c2 |
01 GT
Might need to clean the IAC or replace it. I know on my stang I had to put a spacer in between the TB and IAC that had set screws in it to adjust idle air flow. Start w/ cleanin it though and then maybe replace it if it down't work.
1990 mustang gt
eventually
get a multimeter and make sure your tps is registering .98 volts if not tune it to that
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
Secret In The Works
Good advice. ^^
Also, check to make sure your TB isnt partially stuck open. Check your linkage and inspect the TB to make sure everything is working order.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
Any time a ford has idle problems I always go to the Idle Air Controller (as has already been said). A good cleaning will probably take care of your issues.
^ +1
start with those and then go from there |
Threads Similar to: idle problem.
| Idle Problem | billb303 | 5.0 Mustangs | 8 | May 22nd, 2008 06:03 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| Idle problem /// Need some help ! | das50cal | 2005+ | 12 | July 4th, 2007 06:28 PM |
| HELP!!! idle problem ????????? HELP | das50cal | 2005+ | 1 | June 9th, 2007 09:25 PM |
| Idle Problem | jtlogruss08 | V6 Mustangs | 16 | May 22nd, 2007 05:21 PM |
