speedometer is off
my speedo is way off, i just had a gear change (3.73) and the shop put the red gear in like they should. The speedometer was off when i bought it, so this tells me maybe there is something more serious, what should i do?
87 Coupe
![]() iTrader: 3 reviews
Are your rims a different size? That'll throw it off but they usually try to compensate w/ the tire size.
1990 mustang gt
eventually
is it the 88 gt with a 5 speed?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
What speedo gear is in it?
87 Coupe
said 3.73 rear gear and the red speedo gear.....is that the right combo?
I guess I missed the red part.....
Assuming a 25.5-26 inch tire and the original 5 speed transmission the red gear is the correct gear for 3.73 gears. How far off is the speedo and does it read faster than you are going or slower? Has the transmission ever been changed or rebuilt? Has the speedometer been changed? The factory 88 speedometer is an 85mph unit. If someone put a 140mph gauge face on the stock 85mph speedo it will read faster than what you are going. If the trans is a T5 from a 90-95 Mustang it will have an 8 tooth drive gear which will make your speedo read faster as well but is an easy fix by swapping the red 21 tooth gear for the white 23 tooth gear.
1988 lx
9.68@142
what color is the gear inside the tailshaft housing that the red speedo gear one rides on? there are 2 differnt ones there is a yellow one and a green one. yourse should be yellow.
i have a ford racing 160mph unit. I bought it with thec ar, it as never right. It reads slower than i am going, i think at 28mph i am really doing like 39-40. I dont think the tranny was ever rebuilt. its shot now so i guess i killed the original one.
Is it a Ford Racing speedo or a speedo out of a cop car? I'm betting the speedo is your problem.
1988 lx
9.68@142
put the stock speedo gear back in i bet it will help get it closer it should bring your reading up about 15 mph.
Threads Similar to: speedometer is off
| Speedometer | djh1286 | V6 Mustangs | 12 | January 5th, 2008 02:09 AM |
| Speedometer | akatagyourit | 2.3 Mustangs | 2 | September 15th, 2007 01:24 AM |
| Speedometer | cdesha | 96-98 | 6 | August 15th, 2007 01:11 AM |
| Speedometer | Arhilion | 96-98 | 8 | May 23rd, 2007 07:36 AM |
| Speedometer | 88MustangGT | 5.0 Mustangs | 8 | January 3rd, 2007 07:11 AM |
