Discussing MSD distibutor problem in the 5.0 Mustangs Forum. I have a problem with my MSD #8456 distibutor installation . Any ideas would help . I ...
Old June 16th, 2008, 11:30 PM   #1
Question
I have a problem with my MSD #8456 distibutor installation . Any ideas would help . I have it installed according to all the instructions I have gotten and the engine will run smooth , but when I go to check the initial timing with the spout connector unplugged I get no spark to my timing light , but if I plug the spout connector in I get a spark and the timing light works . I also an MSD 6AL BOX installed and the blaster coil . It's an '86 GT converted to MAF , and everything else seems to operate fine , any ideas ?
Old June 16th, 2008, 11:33 PM   #2
ryans88gt's Avatar
you have the timing light pickup on the #1 plug wire?
no flashing at all? Did you try any other plug wires? Does the car still run with the spout removed? If it does run, then obviously you are getting spark, maybe a problem with the timing light?
89 LX 515 hp 497 ftlbs
88 GT 11.4 @ 118
Old June 17th, 2008, 11:51 AM   #3
Yep the timing light is on #1 plug wire and it does run with the spout connector unplugged. Also , when the spout connector is unplugged I can get a spark from other wires . It seems like the strangest problem I've run into on this project . I'll check the timing light , but it seems to work good on all the other wires if check for spark.
Old June 17th, 2008, 05:13 PM   #4
78mach1's Avatar
after you unplugg the connector, does it still run smoothly? or is it mis firing....i would guess something was wrong with the light, but you said its good
id find another light just to be sure
78 mustang II, mild 306
88 GT
Originally Posted by Darrell View Post
Yeah but the only thing most "old camaro owners" are sporting is a mullet and rotten teeth.
Old June 23rd, 2008, 12:11 PM   #5
OK Just got back from Englishtown drags . I tried a /new timing light with the same results. It does run better when I plug in the spout connector . Also I reinstalled the original distributor to see if that would work . With the old distibutor I have no problem. The timing lights both work fine with that one . Maybe I got a bad distrubutor .? Can they be tested other than being installed in the car
Old June 23rd, 2008, 03:49 PM   #6
humbleLX's Avatar
1989 LX hatch
the tfi have been known to give people problems on the msd's. but they usually either work or don't work, no in betweens. maybe what we have here is a case of "in betweens"
GT40 crate Ecam 1.7RR GT40X alum head GT40 P1SC 12rib IC 12 psi 42inj AFM PMS IV PMAS 3" Flotube BBK 70mm TB 255 Walbro short hdr BBK o/r X, 2ch Flows, way too much to list... if it ain't blown, it sucks...
Old June 26th, 2008, 09:52 PM   #7
Gonna go see a local Mustang guy tomorrow see if he can give me any imput . Got an expensive piece of stuff an it aint doin me no good . Gonna see if its me or the part . Get back to you people , see if its me or a bad part.
Old June 28th, 2008, 07:05 PM   #8
sn94's Avatar
BLWN91GT
If you cant get it straightened out, return the msd distributor because I heard from some local Mustang techs that the MSDs have some trouble with the TFI. Theres no difference between the MSD and the stock distributor. Well besides looks and maybe completing your full MSD setup. Paint the stock distributor, and get the MSD cap and rotor. GOOD as new. Hope u can fix your problem, ill try and find out some word on it.
PaT #06
Old June 28th, 2008, 07:49 PM   #9
ryans88gt's Avatar
I'd just go with the stocker...but it it works when the spout is in, then you shouldn't have any problem other than setting the timing.
88 GT 11.4 @ 118
Old July 3rd, 2008, 11:51 AM   #10
Thanks for the input guys . Gonna try it one more time if it doesn't work Iam going to return it .
Threads Similar to: MSD distibutor problem
MSD hopper 5.0 Mustangs 13 June 25th, 2008 02:33 PM
MSD Carbed 5.0 gtstang87 5.0 Mustangs 0 November 18th, 2007 07:13 PM
msd help mjkids 99-04 2 November 2nd, 2007 05:51 PM
msd terribleonexx88 5.0 Mustangs 9 October 11th, 2007 09:07 PM
MSD? 00RoushV6 V6 Mustangs 2 February 20th, 2007 04:04 PM
