Starter the top end build
Old June 17th, 2008, 09:41 AM   #1
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Started the top end build
Finally picked up the last few odds and ends to get this started. I figure it'll take me 2 - 4 weeks to finish, as I only have a few hours a night to work on the car.
Things that will be tossed on:
TFS Street Heat Heads
TFS Stage 1 Cam
TMoss ported lower for the TFS heads
Accufab 75mm TB
SCT 2400 90mm MAF
42# injectors
JLT 4" CAI
MSD 6AL
Ajustable FPR and gauge
I'm also going to be tossing in the 93 Cobra booster while the blower is off for next years big 5 lug upgrade, as well as fixing the f**king vibration coming out of the Tremec @ 70 mph in 4th.
Can I plug the smog crap at the back of the heads, and just modify the plumbing from the smog pump to run to the exhaust?
Here's some progress pics:
Starter the top end build-dscf0376.jpg   Starter the top end build-dscf0371.jpg   Starter the top end build-dscf0378.jpg   Starter the top end build-dscf0379.jpg   Starter the top end build-dscf0380.jpg
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old June 17th, 2008, 11:09 AM   #2
1992 LX
vortechdroptop is on a distinguished road
Ford sells threded plugs for the back of heads same ones that u have in front.
Nice car BTW
Old June 17th, 2008, 11:17 AM   #3
1992 LX
Since you have TFS heads they might be on there now, if not i can get u part# if needed. Take the smog tubing off and down by the h-pipe just crimp the tube and weld it shut.
Old June 17th, 2008, 11:22 AM   #4
e3sean's Avatar
1988 lx
9.68@142
just get a pipe plug from your local hardware store they are real cheap take the bolt that comes out with you.
<font size=4><b>MILITARY CREW
Old June 17th, 2008, 11:51 AM   #5
1993 Mustang GT
Thanks guys - that tube behind the head annoys the heck out of me. I think I actually ordered two extra threaded inserts from TrickFlow when I bought the heads.
e3sean - I liked your blue hoses so much, I just ordered a set for my car!
Bart
Kenne Bell S/C
GIVE 'ER!
Old June 17th, 2008, 05:19 PM   #6
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
ok so what was your set up before this?
how many pounds were you running? on what fuel?
Old June 18th, 2008, 11:18 AM   #7
1993 Mustang GT
My original setup was simply the Kenne Bell @ 8psi, with a 255 lph in the tank. I only put 94 octane in the car. I've been piecing this together for a while - I should have had it done last summer but oh well.
I'm thinking of bumping the boost with this setup to 9psi before I have the car dyno tuned. Do you guys think the 255lph in tank pump will be enough, or should I get an additional inline pump?
Bart
Kenne Bell S/C
GIVE 'ER!
Old June 19th, 2008, 09:02 PM   #8
1993 Mustang GT
More progress pics:
The ported lower:
The Accufab TB:
Dropped the exhaust and shimmed up the Tremec - it was sitting way too low - put in the original exhaust hanger, and 3 washers a side. Now it looks lie it should.
Coming along faster than I thought. Once all my gaskets and new bolts arrive, I can start putting it back together.
Bart
Kenne Bell S/C
GIVE 'ER!
Old June 20th, 2008, 03:27 AM   #9
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
Yes you'll be fine with 255lph.
Originally Posted by FX4DTUF View Post
a camaro pulls up next to me and i think to my self what would jesus do at a time like this then it hits me he would launch it and power shift the shit out of it
Old June 22nd, 2008, 05:09 PM   #10
1993 Mustang GT
More pics:
Cam going in:
Billet timing chain on:
Lifters back in:
Bart
Kenne Bell S/C
GIVE 'ER!
Old June 30th, 2008, 09:20 PM   #11
1993 Mustang GT
New Cobra brake booster:
Heads and Intake back on:
Bart
Kenne Bell S/C
GIVE 'ER!
Threads Similar to: Starter the top end build
top starter bolt question..... boom-boom 5.0 Mustangs 6 January 25th, 2008 12:06 AM
Starter Top Bolt...... lwhitetrash88l 5.0 Mustangs 8 May 31st, 2007 10:52 PM
Ok guys need help w/ rear end build bloo4.6 99-04 9 April 23rd, 2007 02:59 PM
Top End Build Up 89lx 5.0 89BEAR 5.0 Mustangs 2 January 25th, 2007 07:27 PM
the top end Badasstang281 Modular Mustangs 1 January 3rd, 2007 01:52 PM
