Discussing Oil pressure in my 351C in the 5.0 Mustangs Forum. I have a pinto with a 351C in it. It run's 80lbs of oil ...
Old June 17th, 2008, 02:07 PM   #1
Unhappy
I have a pinto with a 351C in it. It run's 80lbs of oil pressure at idle, but when you snap the throttle the oil pressure goes down instead of up. It seem's to be very unstable off of idle. any suggestions would be great. I have put new oil in and still has the same problem. I am running royal purple 5-30 Thanks Kevin.
Old June 17th, 2008, 02:13 PM   #2
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
maybe your oil pressure sender is tweaking out
Old June 17th, 2008, 04:29 PM   #3
ryans88gt's Avatar
pressure relief in the pump could be stuck or the sending unit has taken a crap.
80 lbs of pressure is not a good thing.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old June 17th, 2008, 05:18 PM   #4
Nowhere to be found
+1 I'd say 65 at highest
Well, guys its been real and its been fun, but it hasn't been real fun for me the past 3 months. Money has been tight and need to cancel my cable service to save what I can. I hope to chat with ya'll in 6-7 months from now. Bye!
Old June 17th, 2008, 05:50 PM   #5
78mach1's Avatar
what kind of guage do you have?...electronic?
go and buy a mechanical one and see waht your readings are
In Memory of Nick Goris.
Originally Posted by Darrell View Post
When I shift, there is no RPM drop. I pound gears like Zippee pounds his meat.
Old June 17th, 2008, 06:43 PM   #6
1989 LX Vert - 1993 Notch
Fast
+1, hook up a mechanical gauge and start from there.
Most engines should see about 20psi at idle and 60psi at WOT
no more.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old June 17th, 2008, 07:05 PM   #7
1983 mustang lx
no more.
i agree
only diesel motors should have around 70-80 psi at or around idle haha
Old June 17th, 2008, 09:33 PM   #8
I have a mechanical guage. That is why I am so concerned. if it was electric It would not bother me to much. Thanks for all your help.
Old June 17th, 2008, 10:43 PM   #9
78mach1's Avatar
well my second guess would be maybe one of your gallies are plogged, or there is some type ok blockage
or like ryan said, your pressure realief valve could be stuck
Threads Similar to: Oil pressure in my 351C
351C Oil pressure kevnsue Classic Mustangs 5 June 18th, 2008 07:01 PM
no oil pressure OneBoredGuy 4V / SVT 10 June 9th, 2008 08:17 PM
Oil Pressure sstang 99-04 2 March 16th, 2008 07:00 PM
oil pressure hmotes 5.0 Mustangs 8 January 18th, 2007 10:30 PM
oil pressure turp V6 Mustangs 1 August 19th, 2006 12:59 PM
