Shifting to 2nd
Old November 8th, 2006, 12:11 PM   #1
88roachs is on a distinguished road
Shifting to 2nd
I replaced my second gear in my T5. i changed the syncro. It still does not go into second properly. I have a new clutch, TO bearing, cut flywheel and new clutch cable. What could be the prob?
Old November 8th, 2006, 05:41 PM   #2
how did the teeth on the gear look where the syncro engages? If they were damaged, it needed to have been replaced. also, look for a bent shift fork and /or the plastic pads being damaged or worn
88 Mustang Coupe
www.rickscarcare.net
Old November 9th, 2006, 09:51 AM   #3
Shift forks were fine, pads changed syncro replaced. One person said it could be the slider that the fork sits on
Old November 9th, 2006, 10:00 AM   #4
that comes as part of the syncronizer which you replaced, right? Or did you just change the springs and inserts on the syncronizer?
88 Mustang Coupe
Old November 9th, 2006, 05:02 PM   #5
After a road test I noticed that it goes into 2nd smoothly when I am above 2000 RPM. What do you think?????
Threads Similar to: Shifting to 2nd
Gears-Shifting 02stang02 V6 Mustangs 1 October 20th, 2007 02:34 PM
power shifting? ddashtrois 99-04 18 April 16th, 2007 10:41 AM
auto shifting APiratesLife4Me 99-04 3 March 23rd, 2007 10:21 PM
shifting mustang1072 V6 Mustangs 22 January 5th, 2007 02:32 AM
hey, shifting??? Tweaked 90LX Drag 3 December 3rd, 2006 06:42 PM
