1990 5.0 LX Notch
AFR Heads
For a car that is not a dd would you put the 225 heads on it? It still has the stock bottom end. But will be going to a 408 some time in the future. Sorry this is on my 90 5.0.
I wouldn't put them on stock 5.0. But if you get them for the 408 they should be fine. I had a buddy that was runnin a 408 with a 205 afr head and first pass off the trailer on motor he ran 10.90.
to many parts and money to be so slow
205s will work with a otherwise stock motor (you'll obviously be wanting an intake). You may need to clearance the pistons, not sure with the stock cam, but the valves will be bigger than the reliefs.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1990 5.0 LX Notch
Running a TFS stage 1 cam.
1989 LX Vert - 1993 Notch
Fast
waste of money and will be a dog down low.
Just wait to put them on your 408
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
People said the same thing about using 265cc 4V cleveland heads on a 351w. But, in actuality it gives up nothing down low.
Fast
thats different.
You will loose a lot of intake runner velocity with those 205's on a 302 with a small cam. You may make good power up top, but your avg. hp over the entire power band will not be as good. You can run big heads on 302, but it requires the right cam and power band.
#8 | |
1990 LX hatch
Fast
I bet you're not running a TFS-1 cam either ...................
#10 | |
It doesn't matter what head you run as long as the rest of the pieces of the total combination match the heads. However, by the sounds of this scenario he is wanting to put 225 heads with 2.08 intake valves on a stock engine which I wouldn't do. For one the valve pockets will need to be cut for the bigger valves and for two the car will be an absolute turd. Not to mention all of the money involved in making the swap (gaskets, rockers, pushrods, head bolts, etc.). Waste of time and money on a 5 liter.
Fast
Like I said, waste of money
and Like I said ...... they will work ...... as long as the cam and power band match
1990 LX hatch
Big runners do not hurt low power numbers and 225cc runners are definitely not big. You just need the rpm to use them. The gains on the top end almost always outweigh the losses on the bottom end. You just need to be careful choosing a cam shaft that meets your needs. Running a large cam will hurt low end power way more than running a big cc head. And AFR has done its research, the 225 cc ports are not lazy ports even on a 302, but to use them to maximum potential you'll need to see the high side of 7500 rpms.
1989 Mustang LX
10.98@126.7 NA
Seems that he wants to buy heads and use them on his stock engine until he can up grade to "the" engine (408). Obviously clearances have to be considered with regard to valves and pistons. The engine will function with the 225s it's just not going to be the optimum combination. Depending on what the actual time frame will be for the new engine, hunting up a decent set of used heads that will match the current engine might be a little wiser. Barring any kind of damage to the "used" heads, recouping his investment from the heads would be fairly easy. The best laid plans of mice and men always seem to miss the mark.
Never fast enough.
i think your best bet is finding a set of used gt-40 (gt-40p) heads until the time that you upgrade the engine, because you can usually sell the used parts for what you paid for them in the first place, then just take that money and put it toward your new aluminum wonders
1990 5.0 LX Notch
Right now I am running 351w heads that have been ported and polished along with a valve job. But I was told these are doing nothing for me.
ported DO heads are probably as good as GT-40 heads.
1990 5.0 LX Notch
how do you tell?
Threads Similar to: AFR Heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| AFR heads | 93hatch | 5.0 Mustangs | 61 | October 9th, 2008 11:44 AM |
| AFR Heads Question | javier351lx | 5.0 Mustangs | 20 | September 16th, 2007 10:38 PM |
| AFR Heads | javier351lx | 5.0 Mustangs | 4 | July 10th, 2007 09:13 AM |
| Afr Heads | javier351lx | 5.0 Mustangs | 9 | July 7th, 2007 06:02 AM |
