Discussing Please Help With Code 66 in the 5.0 Mustangs Forum. haveing problems with my 91 mustang.. when you first start it up it runs great ...
Old November 8th, 2006, 06:01 PM   #1
cptkng79's Avatar
haveing problems with my 91 mustang.. when you first start it up it runs great fro about 30 seconds and then it all turns to crap... major hessitation, backfireing, over 2k rpm.... starts find and idles fine. scanner keeps picking up code 66 which is maf sensor below minimum test voltage, and thats after i changed it. among other parts i swapped out are tps sensor, coil(needed one anyway) ignition modular, o and computer.
my guy at the performance shop is stumped. PLEASE HELP.....
Old November 8th, 2006, 06:25 PM   #2
On Probation
Tony_90fox's Avatar
what MAF did you get?
MM Sapper Squad
Originally Posted by Regency 2007 View Post
MSO's stupidity has never stopped amazing me since the day he joined this forum.
Old November 8th, 2006, 06:26 PM   #3
cptkng79's Avatar
i forget the brand right now
but i know it was new and calibrated to 42 lb injectors
518.9 Wheel HP!!!!!
491 Torque!!!!!!!!
Old November 8th, 2006, 08:32 PM   #4
On Probation
Tony_90fox's Avatar
i was just making sure it was calibrated for the injectors that you have. Sounds like you do...Now its way over my head!
MM Sapper Squad
Old November 8th, 2006, 11:11 PM   #5
terribleonexx88's Avatar
double check you timing
85 4 banger stanger, it likes to sneeze alot when i hit the gas
Old November 9th, 2006, 12:14 AM   #6
cptkng79's Avatar
why do you think it would be the timeing???
tomorrow night my bud is comming over with a meter to test continuity in the 4 maf wires that go to the computer.
any other suggestions, cause im 99.9 %sure the timeing is dead on
Old November 9th, 2006, 01:37 PM   #7
why did u go with that big of a maf sensor.. what kind of injectors do u have
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old November 9th, 2006, 02:02 PM   #8
cptkng79's Avatar
i have a 347 stroked out /supercharged w/10lb of boost right now with 42 lb injectors.
518.9 Wheel HP!!!!!
491 Torque!!!!!!!!
Old November 9th, 2006, 06:00 PM   #9
well the thing is the computer doesent see .5 or .05 volts i forget which one it is but the computer is seeing it... make sure that u have the connector in their real good.. take a volt meter and probe the wires and see how many volts the maf sensor is actually reading... also make sure that all of your cai tubing has no leaks,
Old November 10th, 2006, 10:44 AM   #10
cptkng79's Avatar
does any one know if a faulty fuel pressure red could be to blame
gauge says at idle car is running 19psi with vaccume tube on
tried adjusting it but no luck
Old November 10th, 2006, 03:31 PM   #11
19 psi of fuel pressure...?????????
hell yeh thats bad it should be at 40-44 psi for fuel pressure if thts wht ur talkin about
Old November 10th, 2006, 09:27 PM   #12
cptkng79's Avatar
fixed the prob
it was a faulty fuel regulator
thanx guys
Threads Similar to: Please Help With Code 66
need help with a code 1quickstang02 99-04 4 October 9th, 2007 09:08 PM
Code? jblood37 American Muscle 1 August 26th, 2007 11:27 PM
Code Help MnrlGry01gt 99-04 8 July 24th, 2007 08:52 PM
96 GT vs 64 D-code 289 MustangMatt96GT Modular Mustangs 4 January 11th, 2007 06:34 PM
Code 66 cali 5.0 5.0 Mustangs 3 November 9th, 2006 01:40 PM
