Discussing 91 Mustang GT w/ Excessive Vibration in the 5.0 Mustangs Forum. I just bought my GT before deployment and threw in a King Cobra Clutch Kit, ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I just bought my GT before deployment and threw in a King Cobra Clutch Kit, brand new engine mounts, transmission mount, and a Ford Racing Firewall Clutch Adjuster. Well the hangers on the stock exhaust busted off and took it to a very reputable exhaust shop to get a sturdy set of hangers to welded on. After I took it in, I used the Mustang to pick my wife up from work and on the way home the hangers busted off and flew from the bottom of my undercarriage. I brought the car back to get new hangers put on today and got some advice from the guys at the exhaust shop. They said either the clutch is out of balance or missing some hardware on one or more of the mounts. I just want to know if anyone has some advice on where I should start.
91 Mustang GT -King Cobra Clutch -Power Adder Intake |
1986 Mustang GT
did it just start doing it when you got the clutch put in?
is it only vibrating under load? only while driving? if so, at what speeds/rpm? does it do it in neutral while sitting still and revving?
MILITARY CREW
AT2 |
did you change the clutch quadrant the two peice plastic one might not stay adjusted correctly with that clutch
91 mustang
266 ftlbs 191 hp (15.138 @92.91) @5000ft elevation
your 91 doesnt have an automatic clutch cabel adjuster???
![]() Fender well cold air intake, 3:73's, eibach springs, 65mm TB, electric fans, 3g upgrade, smog delete, advanced timing, MSD cap and rotor, ford racing 9mm plug wires, 75mm Pro-M MAF, flowmaster sieres 40 delta flows |
IT'S TURBO TIME
1990 Mustang LX Turbo
9.71@151.6 mph
did you cut the flywheel?
89 GT
They're not solid mounts for the engine or trans are they?
91 mustang
did you tighten your bell housing to engine and tranny to bell housing bolts????
Threads Similar to: 91 Mustang GT w/ Excessive Vibration
| excessive turnover | CBSTANG | 99-04 | 10 | June 16th, 2008 09:43 AM |
| Excessive Heat | Dallas01GT | 99-04 | 14 | July 30th, 2007 01:43 AM |
| Excessive oil cunsumption in a new motor | jpalm | 5.0 Mustangs | 8 | May 17th, 2007 11:43 PM |
| 2005 auto mustang vibration noise/ rumbling noise | ozan169 | 2005+ | 4 | March 13th, 2007 06:31 PM |
| mass air sensor vibration on 95 mustang 3.8L | rkamp | V6 Mustangs | 0 | August 15th, 2006 07:30 PM |
