Removal of Timing cover
Old June 18th, 2008, 02:19 PM   #1
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Since the oil pan seal sticks into the bottow of the timing chain cover, what's the best way to remove the cover without damaging the seal?
Loosen the oil pan and pop it down 1/2 or so?
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old June 18th, 2008, 03:09 PM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
That will work but it will be a bear to get back on. I don't put the locator dowels in my blocks. I razor blade the oil pan gasket at the block and then when I put the timing cover back on, I put the front part of the oil pan gasket on the timing cover, a small dab of RTV where the cover meets the oil pan (where the gasket is cut) and then line the cover up and torque the cover bolts. Doing it this way you don't have to drop the oil pan and run the risk of it leaking
Never fast enough.
Old June 18th, 2008, 03:22 PM   #3
1993 Mustang GT
Thanks - I'll give it a whirl.
Bart
Kenne Bell S/C
GIVE 'ER!
Threads Similar to: Removal of Timing cover
timing cover Black Five 0h 5.0 Mustangs 3 April 17th, 2008 09:52 AM
Timing Cover 68 dlxcoupe 96-98 3 March 31st, 2008 01:59 AM
Mach speaker cover removal Novanutcase 99-04 0 January 12th, 2008 03:34 PM
my timing cover is aluminum right? YNOT 5.0 Mustangs 4 August 1st, 2007 10:08 PM
Timing cover removal AnglicoGT98 96-98 2 June 24th, 2007 03:51 PM
