Discussing Question About Inop Tach 93 Foxbody in the 5.0 Mustangs Forum. My friend has a 93 Mustang 5.0 all original, everything works but the Tach, ...
Old November 8th, 2006, 06:40 PM   #1
My friend has a 93 Mustang 5.0 all original, everything works but the Tach, it just stopped working, I found an instument cluster out of a wrecked 93 Mustang 5.0 that all the gages including the Tach work. BUT once I buy ( $50.00 ) it I cant return it, my question is: Will the new cluster fix the problem or could it be another part? Togeather we are a couple of boobs when it comes to electrical stuff. Is it the unit in the cluster that normally goes bad? Any help ( Tach Knowledge ) will be greatly appreciated.
Old November 9th, 2006, 01:36 AM   #2
angermgt's Avatar
check connections first start at distributor trace to back of gauge if all is good start car and check for power at connector going into the back of the gauge. dont think tach usually just stops working unless there is a problem with the wiring
490whp/432wtq, V2 13lbs. boost, 3.33 pulley
Old November 9th, 2006, 12:41 PM   #3
thanks for your help, ill keep you posted.
Threads Similar to: Question About Inop Tach 93 Foxbody
Door locks in a foxbody...got a question RIDIN5.0 General Tech 6 June 12th, 2007 08:08 PM
Tach mount in 72 dash question Mach1460 Classic Mustangs 1 March 11th, 2007 04:00 PM
I have a question on installing a tach ocsailor86 96-98 3 February 14th, 2007 04:07 AM
tach notsoslo5.0 5.0 Mustangs 3 January 3rd, 2007 09:20 PM
Tach install Quick question please!! Troyzstang Modular Mustangs 8 November 17th, 2006 06:40 AM
