got it running again
LinkBack (1) Thread Tools
Old June 19th, 2008, 04:07 AM   1 links from elsewhere to this Post. Click to view. #1
e3sean's Avatar
1988 lx
9.68@142
well its running i didnt have time to get it running right tonight ill start on that in the morning but here is a video of right before the first carnk before i hooked the battery back up and then the first carnk.
<font size=4><b>MILITARY CREW
Old June 19th, 2008, 05:44 AM   #2
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
sweet
i have no mustang. so don't listen to anything i say.
Old June 19th, 2008, 11:06 AM   #3
baine21225's Avatar
all i need to see is a burnout to be satisfied
Old June 19th, 2008, 01:46 PM   #4
e3sean's Avatar
1988 lx
9.68@142
baine your like my wife no matter how much i give her she always wants more.
Old June 19th, 2008, 02:08 PM   #5
1992 Lx
11.39@119.24
hahaha u still have the numbers from the track on your car loser, turn the dam tv off next time! so hows it run?
Old June 19th, 2008, 02:38 PM   #6
baine21225's Avatar
Old June 19th, 2008, 03:01 PM   #7
e3sean's Avatar
1988 lx
9.68@142
i went out this morning and adjusted the fuel pressure and the idle and timing. its running alot better there is smoke coming from the driverside collector when i gas it and let off so i need to put the pipe on better. it revs to 6k a hell of alot faster. i havent launched it or stomped it while driving yet i want to fix the exhaust... but good news no lifter tap anymore
Old June 19th, 2008, 03:38 PM   #8
e3sean's Avatar
1988 lx
9.68@142
never mind i figured out what it was... i was wondering why it was smoking with no exhaust leak.... i forgot to put the dipstick back in..and when i let off the throttle oil spit out of the block and on to the header.
Old June 19th, 2008, 05:25 PM   #9
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
What a n00b!!!
Glad to see it running man! Excellent job!
Old June 19th, 2008, 05:28 PM   #10
baine21225's Avatar
hahaha
Old June 19th, 2008, 05:29 PM   #11
e3sean's Avatar
1988 lx
9.68@142
thanks... dude my body has been running so fast my mind cant keep up espically in110*heat. i changed the oil in the truch and didnt take the plug out of the drain container so 5 quarts of black nasty oil that was 5000 miles over its oil change all the way down my driveway that i pressure washed the weekend prior i tried to open the hole but it was hot and i burned the shit out of my hand then i put a glove on and tried to plug the oil pan and burned the shit out of my wrist then i gave up and watched the oil go all the way down cussing the whole time...
Old June 19th, 2008, 05:33 PM   #12
baine21225's Avatar
sounds exciting
Old June 19th, 2008, 05:37 PM   #13
Goblin's Avatar
88mm
Not to change the subject. But, i just wanna say... FUCK THIS ARIZONA HEAT! Its been above 105 all week in Tucson. 110+ most of the week in Phoenix.... I feel for ya Sean.
Old June 19th, 2008, 05:49 PM   #14
humbleLX's Avatar
1989 LX hatch
humbleLX is on a distinguished road
nice n clean....
GT40 crate Ecam 1.7RR GT40X alum head GT40 P1SC 12rib IC 12 psi 42inj AFM PMS IV PMAS 3" Flotube BBK 70mm TB 255 Walbro short hdr BBK o/r X, 2ch Flows, way too much to list... if it ain't blown, it sucks...
Black & Tan
Old June 19th, 2008, 08:03 PM   #15
fogged306's Avatar
89 GT
So what was the injector problem?
Old June 19th, 2008, 08:13 PM   #16
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
not to be picky.. but can you do an idle with rev vid? and is it fitting under your stock hood?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old June 19th, 2008, 08:34 PM   #17
e3sean's Avatar
1988 lx
9.68@142
fits under my hood just fine
but its not stock sorry
Old June 19th, 2008, 08:35 PM   #18
e3sean's Avatar
1988 lx
9.68@142
i think i still have that problem i am taking them out and having them all tested and rebuilt and flow matched i dont want to worry about it any more its time for me to stop being cheap!!!
i hate it i have no problem spending a few hundred on something un nessassary but when it comes to spending 120 on something i need i am too cheap and end up spending twice as much trying to take the chepa way out!!!
Old June 19th, 2008, 10:01 PM   #19
fogged306's Avatar
89 GT
Haha, yea I wouldn't know anything about that... I only have 8k into a 306 that I probably did everything twice on for that exact reason. Had I not been el cheapo, I probably could have had it done for about 4k doing it once the right way. Being cheap doesn't always work out the way you planned
Old June 19th, 2008, 10:37 PM   #20
1992 Lx
11.39@119.24
am i gona have a lifter tap when i put the heads on my car?? like what causes it? too much lift for those heads or something wrong with them or what?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/76521-got-running-again.html
got it running again This thread Refback June 19th, 2008 10:10 PM
Threads Similar to: got it running again
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
running a little better e3sean 5.0 Mustangs 7 March 23rd, 2008 04:10 AM
running mpboy The Clubhouse 5 February 8th, 2008 09:29 PM
Anybody running this?? auburntiger7231 99-04 3 October 23rd, 2007 12:57 PM
not running right jkovacs60 General Tech 2 August 3rd, 2007 02:13 AM
