spark plug lean or rich?
LinkBack (1) Thread Tools
Old June 19th, 2008, 10:51 PM   1 links from elsewhere to this Post. Click to view. #1
e3sean's Avatar
1988 lx
9.68@142
ok so i found the culprit in the studdering its the #2 cylender i am pretty sure its the injector. all the plugs are clean on the tips but black all around the plug. except for the #@ plug it is black around the plug but the tip looks like its a rusted color these plugs have only been used for about an hour total. i think the injector may be dumping too much fuel in and causing the plug not to ignite the fuel when it should causing the studdering at low rpm's
any iput??
<font size=4><b>MILITARY CREW
Old June 19th, 2008, 10:56 PM   #2
ujslost's Avatar
your description throw me of the way you use the words tip and plug.
do you mean the ground strap, or the electrode or the base of the threads?
All three areas are reading points.
Old June 20th, 2008, 12:18 AM   #3
ryans88gt's Avatar
pics please
Old June 20th, 2008, 02:42 AM   #4
e3sean's Avatar
1988 lx
9.68@142
i tried to get a pic but it was way too blury but here is a better description
the base of the threds are black.
Old June 20th, 2008, 02:47 AM   #5
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
Interpreting your spark plugs
pst
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old June 20th, 2008, 02:49 AM   #6
e3sean's Avatar
1988 lx
9.68@142
mine are bran new and dont look like any of those. it has to be the injector i am gettin them done tomorrow.
Old June 20th, 2008, 02:50 AM   #7
chickenbot's Avatar
1990 mustang gt
eventually
mines still down
but im expecting my back pay soon though.. they ran my remedial promotion package threw and i picked up e-3 yesterday..
1990 gt 5.0
3.55 gears
Old June 20th, 2008, 02:54 AM   #8
e3sean's Avatar
1988 lx
9.68@142
good job. some extra cash.. my 4 year raise kicks in on the 15th of next month and i get my cloathing allowance comes this paycheck
Old June 20th, 2008, 02:55 AM   #9
chickenbot's Avatar
1990 mustang gt
eventually
nice.. but i get njped next fri lol but im expecting about 1300 after taxes to come back to me
1990 gt 5.0
3.55 gears
Old June 20th, 2008, 09:33 AM   #10
ryans88gt's Avatar
So if it is a brownish color (I hope that is what you mean by rust color and not actual rust) on the grounding strap that usually means it is a touch rich, but you really need to check the plugs right after doing a WOT pass, pull over and pull the plugs and look at them. Pulling them after it has idled for 5 minutes doesn't really tell you much since they will have cleaned off.
So the #8 cyl looks fine now?
Ghost in the machine?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/76633-spark-plug-lean-rich.html
spark plug lean or rich? This thread Refback June 20th, 2008 04:51 AM
Threads Similar to: spark plug lean or rich?
the A/F gon crazy (rich & lean) mow 2005 - 2010 10 May 23rd, 2008 05:35 PM
Pulse Plug vs. Spark Plug BlckBullitt01 99-04 4 May 18th, 2008 02:51 AM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 09:46 PM
Difference between running rich/lean 1996gt 96-98 3 January 29th, 2007 03:30 PM
car lean..need to trick it to run rich chadjones99 5.0 Mustangs 25 December 8th, 2006 09:55 PM
