Suspension Problem?
Old November 9th, 2006, 12:55 PM   #1
turbong is on a distinguished road
Suspension Problem?
Well i purchased my 90 LX about two months ago now and the other day the front right tire blew out, found out it has been rubbing on something and i don't know what, i can't find where it has been rubbing, one possible place is the shock. The tire has a grove cut into the tire and it rubbed off the entire side of the tire on the inside. Any one have any ideals please help!
"90 LX 12.5 @ 114 / $8,500 invested? How much did you spend on that 13.0 Vet?"
"Treat your car like you treat women: wash, rub down, pamper, then pound the shifter in every gear, drive it till it gets loose and trade it in for a new model!"
Old November 9th, 2006, 01:26 PM   #2
what size tire was it. maybe you need to go smaller in the front.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old November 9th, 2006, 01:30 PM   #3
The car is lowered a little, it has 17x9 Cobra R's 245-45-17
The driver's side is fine, no rubbing at all!? Just the passenger side.
Old November 9th, 2006, 03:32 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
dust sheild maybe?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 9th, 2006, 03:55 PM   #5
shockashark's Avatar
shockashark is on a distinguished road
Were the tires rotated before you got the car...??? Might want to check the rear those tires might have been rotated to the front...
Old November 9th, 2006, 05:04 PM   #6
I have Nitto Drag Radials on the rear! And driver's side isn't doing it.
Pictures and other comments can be found here,
http://bbs.hardcore50.com/vbulletin/...ad.php?t=36796
Old November 9th, 2006, 05:06 PM   #7
Originally Posted by 95opal
dust sheild maybe?
Don't think so but i'll take a closer look tonight when i get home. Should be almost impossible for that to happen.
Old November 9th, 2006, 05:12 PM   #8
Here are the same photos i have on the other site:
Old November 9th, 2006, 06:35 PM   #9
maybe that one side was lowered more. LOL
[SIGPIC][/SIGPIC]
Old November 9th, 2006, 06:44 PM   #10
95opal's Avatar
95 opalfrost gt
At first i said dust shield but looking at the first pic it seems like its alot higher up. So maybe shock or ( wild guess ) the bracket that holds the brakeline. Look around in there your bound to see something thats got some markes on it.
5.0 magazines
Old November 10th, 2006, 04:16 AM   #11
91GRNGT's Avatar
91GRNGT is on a distinguished road
Send a message via MSN to 91GRNGT Send a message via Yahoo to 91GRNGT
yeah man there is no way a dust sheild would cause that, I would say that the tie rod end maybe??? I would look carefully and rub your hands slowly over any part u can think of, u will find something, or if u can't find anything and didn't hear any noises then it "may" be possible that ur belt broke in that tire and then after a while she blew... If u don't see any rub marks or heard any noises then that could be a option. hope this helps.. A tie rod end is about the only thing I would think could do a line like that other than a broke belt..
1991 Mustang GT 306, with KB .30 over pistons, steeda #18 cam!
05 Dodge Neon "Daily driver" Does dodge and ford match???
Old November 11th, 2006, 08:57 PM   #12
Well i got the new tire put on the car and set the car back on the ground, it seems like it is the plastic cover that goes over the shock, i cut it off. It had like 1/4 of an inch of space just sitting on level ground. So i'm sure on curves and driveways and big bumps it was really rubbing. I'm gonna try it out this way for a while and see what's up..... Thanks alote to all of your input and ideals. I post later on after i see if it rubs any more....
Old November 12th, 2006, 11:48 PM   #13
IcantDo55 is on a distinguished road
245's are too big for a Fox. 225 on the Front should be max and a 17x8 rim is a better fit than the 17x9
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old November 13th, 2006, 08:23 AM   #14
Well there's not much i can do about it right now, unless i find someone who wants to trade two 17x9s for two 17x8s. I have 235 45s on it right now untill i find some one who will trade.
Threads Similar to: Suspension Problem?
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
New to suspension 2000Mustang General Tech 9 March 11th, 2007 03:50 PM
Header or suspension problem? mystang428 99-04 3 March 1st, 2007 09:09 PM
Suspension dr.gonzo! 5.0 Mustangs 0 January 24th, 2007 01:58 PM
89 Fox Suspension OTreborO General Tech 9 October 6th, 2006 01:54 AM
