Discussing Rear End questions..and tire question. in the 5.0 Mustangs Forum. Ok, I really wanna start doing the rear-end in my car soon.. I want ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
91 Mustang LX Fastback
1000.00
Rear End questions..and tire question.I want to run Strange Axles with C-Clip Eliminators.. But im hearing there not that great, and to look at Moosers. What should I be looking at? Maybe a diff brand altogether? I than want to pick up a rebuild kit for the posi... As for gears.. I think im set on going up to 3:73's. Are the the "Ford Racing" gears any good? And last one right now.. Tires. I want to get either the BFG's or M/T radials. But looking at the dimensions. There both 60 series, but the bfg is 28" tall, and the M/T's are only 26.1" tall.. Is that right? Brett!
91 Mustang 4cyl Project Car 5L (for now), AOD, Subframe Connectors, 10 Hole Rims, 8.8 Rear End.. MORE TO COME! Yes my name is Brett, Yes im from Canada.. NO! My last name is NOT Hart! |
1000.00
UP!!!
IT'S TURBO TIME
1990 Mustang LX Turbo
running Strange an C Clip elimantors no problem here
Put up, Shut up, Line Up And Get Beat Up!!! |
1000.00
What spline should I look at..?
Cause I need a different center section to run 31's, right? Brett!
IT'S TURBO TIME
idk the rear end i bought had a locker in it an the the 31s went in just fine
1000.00
Ok, i gotta bring this back up...
Starting to bring the money in.. And I need the answers.. What spline axle should I be looking at? Also, are the "Ford Racing" gears any good? Or should I be looking at a different brand? Brett!
The ford gears are some of the best.
you can use 31 spine axles with the 03/04 cobra trac-lok differential, which you can pick up cheap on ebay and will hold ~500 hp. As for the tires you can get M/T drag radials in 50 series which are 26 inch tires or 60 series which is a 28 inch tire. But this depends on the particular tire. Best bet is to look it up on summit where they give you the actual dimensions.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
1000.00
Ok, well that answers my gear question than. I think I will look at ordering some 3:73's soon.
As for the posi. I really want to use the stock one I think. So what spline? 29? As for tires.. I looked up the dimmensions on Jegs, and apparently the 60 series M/T's are 26".. And the 60 S BFG are 28".. Does that make sence? Brett!
1000.00
Ok, well now im left thinking..
What is the stock posi willing to take, power wise??? And ya, tire question still. To mee that dosent make any sence. But im not sure. Brett!
#10 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Strange makes some of the best stuff out there. Moser is pretty good too. Ford Racing gears are good. Two companies manufacture gears for Ford, Richmond and Motive......the only two that I know of anyway. Tire dimensions depend on the size. Both M/T and BFG make a variety of sizes to suit your needs. M/T seems to have the upper hand in the drag radial market as far as performance goes.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#11 | ||
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Read what Ryan said in his post.
1000.00
Well, I checked online on Jegs, and the tire demensions are diff..
I figured at 60 Series BFG would be just as tall as a 60 Series M/T.. I think im set on strange axles. As far as what im going to use it for. It'll see the track like everyother weekend. Car is an auto. And I want to run the biggest spline, I just dont know what the biggest is that I can run with the stock posi.. Brett!
31 spline is popular & much stronger than stock you will need a different posi when you change axle spline count.Like Ryan said before see if you can find a 03/04 cobra posi which is 31 spline, BuyFordRacing.com has em too.
Speed kills drive an import and live forever. 1991 LX 5.0 H/B 1990 T-BIRD SC |
#14 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
You can run a 31 spline if you use an 03-04 Cobra traction lock.
1000.00
Ok, well that answers all that for me than...
So ill be stuck with a 29 spline unless I go over to a new Posi. And since I dont see it happening on the budget im on I may be just picking up some 29 Spline Strange 4 luggers with C Eliminators.. I guess that answers all of my questions for now. Thanks guys! Brett!
1989 LX Vert - 1993 Notch
Fast
#17 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
I really don't think I'd waste the money on aftermarket axles, c-clip eliminators and all of the related parts and stay with a 28 spline factory traction lock. To me it seems like kind of a waste when you can get a 31 spline set of axles for the same price and they are much stronger. 03-04 Cobra traction locks are available all over the internet as well.
1000.00
My bad.. Why was I thinking 29 spline??
Maybe ive been around Chevys to long?? Well, roughly what would I be looking ato for one of these trac lock thing a ma bobers? Brett!
they cost around 300 bucks but depending where you look could be less for a 03/04 cobra posi
88 Gt
not slow
250.00 for cobra tracc lock on buyfordracing.com
Threads Similar to: Rear End questions..and tire question.
| Rear End Questions | gtcs mustang 13 | Modular Mustangs | 34 | November 23rd, 2007 09:04 AM |
| rear end questions????? | the88-5.0 | 5.0 Mustangs | 4 | September 21st, 2007 01:47 AM |
| rear end questions | jasperstang308 | General Tech | 1 | September 5th, 2007 03:33 PM |
| Questions about 8.8 rear end gears | Smoph | 5.0 Mustangs | 27 | March 7th, 2007 09:00 PM |
| Questions about a 10.5 rear rim and tire | 03graypony | 99-04 | 16 | December 29th, 2006 04:34 PM |
