Discussing Bad Lag Help plz in the 5.0 Mustangs Forum. My 94 GT has been running really bad lately once i start it up it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1994 Mustang GT
TBA
Bad Lag Help plz
My 94 GT has been running really bad lately once i start it up it will run good and strong for about 10 min. then the rest of the day it sucks. I will step into the gas and it seems like the motor is holding back. When it runs strong my car pulls really hard in 2nd at 4k but when it lags it will not go anywhere but it seems to run better when i get the accelerator about 25% down.
I have changed the Spark Plugs and wires, Fuel Filter, and MAF Sensor but it still seems to act up. Any ideas?? |
1989 GT
KB 2.1L Flowzilla
Coolant temperature sender?
1989 LX hatch
what is ur TPS set to? r u throwing any codes for ignition or fuel components?
GT40 crate Ecam 1.7RR GT40X alum head GT40 P1SC 12rib IC 12 psi 42inj AFM PMS IV PMAS 3" Flotube BBK 70mm TB 255 Walbro short hdr BBK o/r X, 2ch Flows, way too much to list... if it ain't blown, it sucks... Black & Tan |
1989 lx convertable
11.30
+ 1 ("Coolant temperature sender?")
for the computer not the gauge |
1994 Mustang GT
TBA
i dont know what my tps is set to and i am going to run the codes tommorow but i dont think its the coolant temperature sender cause it seems to be more of a fuel or electrical problem
1988 lx 5.7
11.6@109
blown head gasket?
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331 MILITARY CREW USAF LUKE AFB AZ, E-5 SELECT 7995 AMMO I.Y.A.A.Y.A.S |
88 Gt
Not Slow
88 Gt
Not Slow
thats tough
1989 Mustang Gt
Run me and find out!!!
tru dat
331 ways to WASTE an LS1... ![]()
1988 lx 5.7
11.6@109
it would make sence once it warms up and the water pressureizes and seeps into the cylender it will jack up the air fuel ratio and u would loose power..
Asshole™
1990 Mustang LX
9.36@143 mph
Test the coolant temp sensor. A simple google search will tell you what the specifications should be. You might be able to find the specs on Autozone or Advanced Auto Parts websites. If that checks out, pressure test the cooling system with the car warm.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
how about clogged cats
Speed kills drive an import and live forever. 1991 LX 5.0 H/B(T-70 turbo coming soon) 1990 T-BIRD SC(daily driver) |
2002 V6/1967 Mustang
I had the same issue on my 91, Cleaned the Idle control and its now MUCH better.
2002 V6 Mustang/ 5 Spd, cold air, flowmaster exhaust, Hedman Headers 1991 LX 5.0 Convertible, Flowmaster 40's 1991 LX 5.0 Hatch, offroad h pipe, Flowmaster 40's 3.77's with a locker |
That should only effect the idle, and the idle would be better when warm with a bad iac
His car is fuggin up when warm.
FREE LUNCH, FINAL WISDOM, TOTAL COVERAGE... WHY NOT?
+1 on darrel and sean, you can do both of those test very quick and easy
This is exactly how mine was acting as well..... All the symptoms of a blown head gasket without the compression loss or oil/antifreeze mix.
Asshole™
1990 Mustang LX
9.36@143 mph
Definitely a possibility as well but I'd check the easy things like the coolant temp sensor and a cooling system pressure test first.
Threads Similar to: Bad Lag Help plz
| Site Lag | 8t6gt | The Clubhouse | 18 | December 12th, 2007 12:02 AM |
| Throttle Lag | superpede1 | V6 Mustangs | 21 | August 30th, 2007 04:31 AM |
| lag | stanged out | V6 Mustangs | 11 | May 13th, 2007 05:05 PM |
| WOT LAG!!!!!! | terminal velocity | Modular Mustangs | 5 | May 5th, 2007 03:33 AM |
| LAg when I press the gas | nHuman | 96-98 | 7 | December 25th, 2006 03:41 PM |
