Burning Oil
Old November 10th, 2006, 03:36 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
Burning Oil
i know my piston rings are junk. but since my last oil change under heavy acceleration i make a smoke screen from my exhaust could this be from using 10w-30 now, instead of 5w-30? i installed an air/oil seperator in my pcv line to stop some oil burning but it nstill smokes bad. i also noticed it doesnt smoke when cold only when its fully warmed up. would motorcraft 5w-20 change anything.
85 svo. work in progress
Old November 10th, 2006, 03:47 PM   #2
cali 5.0 is on a distinguished road
the oil rings on ur pistons could be gone and it could also be an excess amount of carbon built up in the cylinders which would explain why it only does it when the motor gets warm.
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old November 10th, 2006, 04:06 PM   #3
i recently used seafoam to get rid of the carbon build up
Old November 10th, 2006, 04:10 PM   #4
mdvaldosta's Avatar
11.47@120.58
Lower viscosity oil would make smoke from a ring problem worse, you would want to go with heavier oil... like 10w40 (although that's not as good from a performance and possibly protection standpoint).
Old November 10th, 2006, 04:43 PM   #5
wouldnt thinner oil not stick to the cylinder walls as much
Old November 10th, 2006, 07:43 PM   #6
so i took off the oil seperator and its stopped smoking now its only smokes under w.o.t maybe oil residue still in the intake manifold
i thought the seperator was suppose to help
Old November 12th, 2006, 11:51 PM   #7
IcantDo55 is on a distinguished road
Does it have alot od blow by?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old November 13th, 2006, 12:28 AM   #8
i wouldnt know the difference between alot and normal
Old November 13th, 2006, 01:16 PM   #9
@ idle there should not be any...is there?
-Mike
Link to My Site
Stroked and Blown!
Old November 13th, 2006, 04:00 PM   #10
at idle when i pull off the tube from the t/b to the oil filler neck it smokes and i rev it and smokes more. but my idle is around 1300 rpm so if the idle was 600-700 there would be less blow by. im working on fixing the idle today so ill see what happens with that
Old November 13th, 2006, 11:01 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is it bad rings or is it bad valve seals and/or valve guides. Is the PCV system functioning properly?
Old November 13th, 2006, 11:45 PM   #12
yes
Threads Similar to: Burning Oil
Burning Oil ddashtrois 99-04 7 July 8th, 2010 04:24 PM
burning oil??????? 5LBennett 5.0 Mustangs 20 July 4th, 2007 12:34 PM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 10:46 PM
burning oil dragpipe General Tech 0 February 25th, 2007 04:40 PM
Burning Oil thewayshemoves 99-04 4 December 27th, 2006 12:25 PM
