1990 mustang gt
eventually
starting fresh
what would be a good block to go with for a replacement
Engine Blocks, FORD - summitracing.com
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
88' Coupe & 92' HB
Well my selection from that page would be:
World Products 351 Ford Man O'War Blocks Engine Block, Cast Iron, 4-Bolt Mains, 3.990 in. Diameter Bore, 1-Piece Rear Main Seal, 9.5 in. Deck,Ford,351W OR Ford Racing 351 C.I.D. Non-Siamese Bore Engine Blocks Engine Block, Cast Iron, 4-Bolt Mains, 4.000 in. Diameter Bore, 1-Piece Rear Main Seal, Ford, 351/ 5.8L, Each You did not specify a budget so that would be my picks. |
#3 | |
1992 Lx
11.39@119.24
why would you want to replace your block? just bore it .030 over good as new
1988 lx
9.68@142
depends if u are on a budget and what u want to do with it. i would just get a seasoned 351w block
if u want a 302 based block to hold a lot of boost or alot of compression i would get the boss block if u just want as much power as you can, get the 460 cid ford racing block.
1990 mustang gt
eventually
something that will fit under a stock hood like the 302.. or should i just do what 93hatch said and just bore it over .030.. if i were to do that what would the bore be then?
1991 5.0 5speed mustang
306
1990 mustang gt
eventually
what size pistons would i put in there?
1983 mustang lx
a 306 and 347 uses 4.030" pistons if youre talking about the bore size.
Threads Similar to: starting fresh
| Fresh | karma | New Members Introductions | 12 | December 3rd, 2007 07:20 AM |
| Jersey Fresh! | JayhoodCrack | New Members Introductions | 6 | July 16th, 2007 01:42 PM |
| FRESH OUT THE PACKAGE | DJ-Visionz | Multimedia | 12 | September 29th, 2005 02:23 PM |
