taking my injectors to get flow matched.
Old June 25th, 2008, 05:54 PM   #1
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
man i have been procrastinating doing it but i have to it cost $15 each to have them tested taken apart cleaned re assymboled new pintle caps new seals flow matched and re tested. thats the cheapest i have found most places its 17-25.00
<font size=4><b>MILITARY CREW
Old June 25th, 2008, 11:13 PM   #2
1987 ford mustang gt
well see when shes done
buy a new set or quit telling us you are going to do it and not doing it.
Old June 26th, 2008, 02:18 AM   #3
e3sean's Avatar
1988 lx
9.68@142
i dropped them off today mofo! and i did something pretty sweet to my car ill post it up in bout an hour..
Old June 27th, 2008, 12:02 AM   #4
tmoss's Avatar
tmoss is on a distinguished road
now, if you could just get all your runners to flow the same..................
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old June 27th, 2008, 12:03 AM   #5
Old June 27th, 2008, 02:00 AM   #6
e3sean's Avatar
1988 lx
9.68@142
ohh they do the trickflow intake flows the same all the way around. way better then the gt40.
Old June 27th, 2008, 10:47 AM   #7
tmoss's Avatar
really? did trickflow tell you that?
Old June 27th, 2008, 11:50 AM   #8
ryans88gt's Avatar
They are MORE evenly matched, but I wouldn't say completely even. The front runners are still going to be a little slower...the distributor pushed the front intake runners back on almost every EFI intake manifold.
Old June 27th, 2008, 02:28 PM   #9
e3sean's Avatar
1988 lx
9.68@142
no my machene shop told me that they flow nearly the same on every runner stright out of the box. if u have ever looked at the lower intake not on the car the runners are very short and very stright.
ryan you are right i am sure they dont flow the same down to a single cfm but ill find out the numbers and report back
Old June 29th, 2008, 04:53 PM   #10
tmoss's Avatar
Exactly, the upper to lower intake transition for #1 and #5 is physically behind the #1 and #5 ports in the heads, I don't care what you do to the intake, there is a turn to be made and it slows down the air charge. "straightening" the #1 and #5 runners is a misnomer - you want to maximize the radius and align the runners with the head ports as well as possible. I've flow tested a TF or two also.
Old June 29th, 2008, 05:13 PM   #11
Hunt_chevs's Avatar
2002 Gt
Not Slow
what cool shit did you do?
Old June 29th, 2008, 05:18 PM   #12
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
^^ ya what the hell?
Old June 29th, 2008, 06:31 PM   #13
tmoss's Avatar
I don't know who your asking, but if it's me, my website is full of the stuff I do.
Old June 29th, 2008, 07:28 PM   #14
78mach1's Avatar
no e3sean said he had done some cool stuff in his second post, said it should be up in about an hour.
its probably under glow or a nos sticker lol
Old June 29th, 2008, 09:55 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Your machine shop is on crack. All small block Ford intakes suffer on the front two runners. Those cylinders are the ones that always go lean. I even tested a prototype intake from a big name company on one of my engines that was supposed to virtually eliminate the lean condition but it didn't do any better than my Super Victor.
Threads Similar to: taking my injectors to get flow matched.
50 lb injectors and mass air flow sensor mustank Modular Mustangs 8 December 31st, 2007 11:31 AM
Block-Heads Mix/Matched Question tdf 5.0 Mustangs 1 June 20th, 2007 01:47 PM
