Idle
Old November 10th, 2006, 09:24 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
Idle
i cant get my idle normal. i checked for vacuum leaks didnt find any.i bought a new iac. checked the idle screw. its idles around 1300 rpm i unplug the iac and the idle drops and the car tries to stall. i used the idle screw to set the idle at 600-700 rpm with the iac unplugged and its fine then when the iac electrical connector is put back on the idle shoots right back up.
85 svo. work in progress
Old November 10th, 2006, 10:30 PM   #2
03svtsnakevert is on a distinguished road
check your TPS for proper voltage
.96-.98 DC
Previous and Current Rides:
1967 Ford Mustang Coupe
2002 Ford Mustang GT--SOLD!
1967 Ford Fairlane 500 XL--SOLD!
2003 Ford Mustang Cobra 1 of 308--SOLD!!
2003 Kawasaki Mean Streak--SOLD!!
2006 Harley Davidson Screamin' Eagle V-Rod
Old November 11th, 2006, 03:33 AM   #3
dcraig8 is on a distinguished road
ditto
Old November 11th, 2006, 04:06 PM   #4
i tried it reads 5 volts constant
Old November 11th, 2006, 07:52 PM   #5
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
try and get it closer to .98 or so. If you have to elongate the holes in the tps to get more adjustment. good luck
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 12th, 2006, 07:13 AM   #6
+1
Old November 12th, 2006, 10:43 PM   #7
IcantDo55 is on a distinguished road
http://www.moddedmustangs.com/forums...dle-vt268.html
Please drive through...
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old November 12th, 2006, 11:30 PM   #8
do you leave the idle screw where it is when you set the idle
Old November 13th, 2006, 10:46 AM   #9
Read the write up.
-Mike
Link to My Site
Stroked and Blown!
Old November 13th, 2006, 05:55 PM   #10
so i did the whole set the base idle thing it didnt work. i took out the egr plate cleaned the crud out tried to set the idle again. the idle is fine with out the iac hooked up. i set the idle screw but once i plug in the iac the idle goes from 700 to 1300. the iac is brand new. i tried adj. the tps but its a constant 5 volts . one o2 sensor has a wire broke off it so i wanna change the 2 o2 sensors and after that i have no ides. right now i have a steady 700rpm idle with out the iac plugged in .
Old November 14th, 2006, 03:08 AM   #11
91GRNGT's Avatar
91GRNGT is on a distinguished road
Send a message via MSN to 91GRNGT Send a message via Yahoo to 91GRNGT
PISS on the IAC then lol, that is my 2 cents, hell what is the worst that could happen? Does it stay constant when u run the heater or the ac??? It is supposed to help your engine under a load, check these and if it runs great under a load, then run it... U can take my advice with a grain of salt, as I am a newbie lol...
1991 Mustang GT 306, with KB .30 over pistons, steeda #18 cam!
05 Dodge Neon "Daily driver" Does dodge and ford match???
Threads Similar to: Idle
idle help? bone_crusher V6 Mustangs 5 August 18th, 2007 02:59 PM
IDLE GOES UP AND DOWN WHY? GTSHAYE$ 94-95 2 May 9th, 2007 11:30 AM
idle...... sivart 5.0 Mustangs 4 April 26th, 2007 01:09 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
need help my 88 won't idle smokin' joe 5.0 Mustangs 2 August 25th, 2006 03:59 PM
