Speed Density to MAF?
So, if I bought an '87 Fox, it would come with the speed density instead of a Mass-Air Sensor right? Is there any way of converting? How hard would it be?
"It's not until you've lost everything, that you're free to do anything"
You need the harness, computer, maf meter from a mass air car. As for how hard I can't really say cause I converted my car when the motor was out of it.
1987 Mustang GT
pretty simple to do I purchased a kit from a guy on e-bay and it worked perfectly
Threads Similar to: Speed Density to MAF?
| MAF vs. speed density | UNFStang | 99-04 | 3 | June 4th, 2008 11:19 AM |
| Speed Density to MAF conversion computer | Project_Stang | 5.0 Mustangs | 2 | September 28th, 2007 03:22 PM |
| 1986 Mustang 5.0 HO speed density to MAF | 1st fox body | 5.0 Mustangs | 6 | May 20th, 2007 07:14 PM |
| Speed Density VS MAF | Tr1gger | 5.0 Mustangs | 7 | April 17th, 2007 10:24 PM |
| Speed Density or MAF? | 8A_Honda | 5.0 Mustangs | 15 | February 6th, 2007 08:04 PM |
