GT40 Heads Intake - Page 2
LinkBack (1) Thread Tools
Old June 29th, 2008, 08:36 PM   #21
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
nevermind.....read ryans post again and said he didn't need need it and could unplug the vacuum line and make sure the egr valve was closed. Might just make a block off plate or thread it and plug the hole. Now that I think about it my 91 w/ the holley had the vacuum off and valve closed w/ no probs. Ya'll been a big help. Thanx again.
Old June 29th, 2008, 11:40 PM   #22
ryans88gt's Avatar
you can run without the EGR all together by getting an EGR delete plate that will take the place of the EGR spacer (that normall goes between the throttle body and intake).
eBay Motors: MUSTANG EGR PLATE DELETE 70mm BILLET 70 mm 65mm 65 mm (item 350073148972 end time Jun-30-08 10:53:57 PDT)
Then if you want to keep your car from throwing codes, you can buy this...
eBay Motors: MUSTANG EGR ELIMINATOR /SIMULATOR 1987-1995 (item 360065250290 end time Jul-03-08 09:59:07 PDT)
It plugs into the wiring harness and keeps the computer from throwing codes and also from doing the EGR timing advance.
However, just unpluging the vacuum from the EGR will work too.
Old June 30th, 2008, 07:43 PM   #23
87 Coupe
Thanx bro. Figures it be something stupid as that. Like I said his bro just kept tellin him wrong info. Thanx for all your help guys.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/77707-gt40-heads-intake.html
GT40 Heads Intake This thread Refback June 26th, 2008 10:04 PM
Threads Similar to: GT40 Heads Intake
358w/GT40 Heads/302 Intake Question teal89 5.0 Mustangs 18 May 15th, 2008 08:54 AM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
gt40 heads.... fastford3388 5.0 Mustangs 4 March 9th, 2007 05:49 PM
gt40 p heads 03stanger 5.0 Mustangs 5 January 6th, 2007 12:14 AM
