Harmonic Balancer
Old November 11th, 2006, 11:35 AM   #1
shockashark's Avatar
shockashark is on a distinguished road
Harmonic Balancer
The balancer was using a standard 4 - 3/8 bolt setup and I made a big mistake by over tightening... I decided to thread up to a 1/2 bolt and it worked well but now I have to make all the bolts the same size to keep it in balance... :-(
Why didn't you guy's tell me that this thing balances the motor on the inside and outside...
My question is " How sensative are these things to being retapped to a larger bolt pattern ???"
Old November 11th, 2006, 03:49 PM   #2
03svtsnakevert is on a distinguished road
not something I would do...but that is just me
Previous and Current Rides:
1967 Ford Mustang Coupe
2002 Ford Mustang GT--SOLD!
1967 Ford Fairlane 500 XL--SOLD!
2003 Ford Mustang Cobra 1 of 308--SOLD!!
2003 Kawasaki Mean Streak--SOLD!!
2006 Harley Davidson Screamin' Eagle V-Rod
Old November 12th, 2006, 02:58 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Balancer
Outside what do you mean? The balancer is used to balance the rotating mass inside the motor as is the flywheel for the rear. Not something I would do either.. Why dont you just remove the balancer and use a Heli-Coil and use the stock size bolts?
Old November 12th, 2006, 09:56 PM   #4
Instead of wrecking something I just went and bought a new one along with pulley setup... Ya the Heil coil was a good thought but may as well do it new since the stang will be seeing track time...
Old November 12th, 2006, 10:08 PM   #5
:award
you are the man!!!
Old November 12th, 2006, 11:19 PM   #6
Justincredible's Avatar
Justincredible is on a distinguished road
Not that it matters now....
As long as you drilled the same amount of material out of each hole and tapped it to the same depth for each hole... you would not of had any problems at all.
Same goes for the heli-coil idea.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Threads Similar to: Harmonic Balancer
Harmonic Balancer dreamr 5.0 Mustangs 9 October 30th, 2007 09:54 PM
Harmonic Balancer Fastpitchdad 5.0 Mustangs 0 February 19th, 2007 03:21 PM
Harmonic Balancer shawn91stang 5.0 Mustangs 4 January 6th, 2007 01:24 AM
Harmonic Balancer cobraetti 5.0 Mustangs 2 December 3rd, 2006 10:23 AM
