LinkBack (1) | Thread Tools |
#1
You have any experience with this??
So I have a 95 GT, and about 2 years ago after the car had been running hot I had taken it to a local shop who told me it was using more coolant than they could keep in it. He said coolant was pooring into the oil, or visa versa. So not having the money to fix it right then I just let the car sit. Now Im selling it to my cousin and we had just finished bolting the heads and intake back on after changing the head gaskets however, not only did the head gaskets look good, so did the cylinders, and the heads. So we are starting to think maybe the guy wasnt being honest about the car. It has never leaked antifreeze, and never smoked.... Is it possible he misdiagnosed the cars condition? Or maybe is there a bigger problem like a cracked block? If so, where is the fluid? When the car was running it seemed to me that the fan either wouldnt come on until it was too late, and if it did, it wasnt high speed. I had then changed my thermostat, engine coolant temperature sensor, and water pump. We should be ready to fire her up tomorrow.. But if you have any suggestions Im all ears. Sorry for the long post...
1989 Mustang LX
10.98@126.7 NA
Run a pressure test on the cooling system
Never fast enough.
89 GT
Did you check the oil to see if there was antifreeze in it? If you let it sit with antifreeze in the crankcase, you probably have some shot bearings.
Nope, didnt see a drop... Everything look good, especially for 173k on her. Put everything back together and started her up, adjusted the timing and she ran good. Let her idle for a while, so far so good. Tried to take her for a spin, but now we have the clutch issue. It wont go into any gear when running.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/77753-you-have-any-experience.html
| You have any experience with this?? | This thread | Refback | June 27th, 2008 07:36 AM | |
Threads Similar to: You have any experience with this??
| Anyone who may have experience this!! plz help | Killax15 | 99-04 | 10 | June 28th, 2008 12:30 AM |
| your best experience | Black Five 0h | 5.0 Mustangs | 3 | May 6th, 2008 04:15 PM |
| Anyone w/SVO experience? | sweet99 | 96-98 | 4 | November 7th, 2007 05:34 PM |
| Anyone with S10 experience? | mikebert | The Clubhouse | 8 | September 10th, 2007 04:23 PM |
| First experience with a programmer!?!?! | RStrick0352 | 2005 - 2010 | 1 | May 2nd, 2007 11:35 AM |
