Lost Timing Chain Cover Bolts Help
Old June 28th, 2008, 01:22 AM   #1
rusty2407's Avatar
1991 Ford Mustang LX
rusty2407 is on a distinguished road
im swapping my engine in my 91 5.0 and lost the bolts to the timing chain cover, does anyone know where i can get some new ones, they are the special bolts where its thread, nut, threads for the waterpump. Please Help
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters
Old June 28th, 2008, 05:12 AM   #2
e3sean's Avatar
1988 lx
9.68@142
naah u dont need it it is a 5/16x18 thred bolt and you dont need the one your thinking of. i didnt use mine just get a bolt long enough.
<font size=4><b>MILITARY CREW
Old June 28th, 2008, 09:55 AM   #3
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
You can get a 302 water pump kit from ARP, but it will not have the water pump
accessory bracket bolts like you are talking about.
If you call ARP, you can send the bolts in and they will send you
the right ones in exchange. Dont know why they dont have kit for it though.
What I did was get a 3/8 nut to use as spacer on the 5/16 bolt
between the water pump and accessory bracket to push
the bracket out that little bit like the stock bolts do.
It's a bit of a pain getting the front bracket on and off, but it works fine
and everything lines up properly.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Threads Similar to: Lost Timing Chain Cover Bolts Help
Roller Timing Chain red2k2gt 99-04 0 May 30th, 2008 08:33 PM
timing chain cover mpboy 99-04 3 March 16th, 2008 10:10 PM
TIMING CHAIN REPLACEMENT CRZCOBRA Modular Mustangs 1 July 9th, 2007 05:49 PM
4.6 V8 4v timing chain set-up Mauriello Motorsport 4V / SVT 2 May 25th, 2007 11:10 PM
