Discussing Clutch Popping in the 5.0 Mustangs Forum. I think its the pilot bearing, but maybe ya'll can help me out. When ...
Old November 11th, 2006, 08:52 PM   #1
Clutch Popping
I think its the pilot bearing, but maybe ya'll can help me out. When I release my clutch pedal you can hear/feel a pop. That happened after I started to feel my car vibrating, and its through all the gears. Its not a big vibration but you can feel it. My clutch is a new centerforce mybe 1500 miles on it. Thanks in advance.
daily driver, n/a, 91gt, e-cam, roller rockers FMS 1.6, silencer pulled with k & n, 3.55 gears, aluminum driveshaft, ud pullies, mac exhaust (2.5"), flowmasters,
Old November 11th, 2006, 09:19 PM   #2
1984 GT
13.79@98.99
If your car in in neutral with the clutch out ..... the only thing moving in the trany is the pilot bearing.
So indeed there is a good chance it is the pilot bearing. However when my pilot bearing went out it didn't pop but it make a but load of noise.
jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over.
Old November 11th, 2006, 09:25 PM   #3
well even with the car off it still pops.
Old November 11th, 2006, 10:03 PM   #4
Did you grease where the release bearing slides on the input shaft, maybe it is binding or the release lever is too loose on it's pivot ball?
Old November 12th, 2006, 09:48 PM   #5
sounds like the clutch quadrant is gone... mine did the samething and the clutch quadrant needed to be replaced....
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old November 12th, 2006, 10:14 PM   #6
just put a new steeda double quadrant
Old November 12th, 2006, 10:26 PM   #7
wht about the cable
Old November 12th, 2006, 11:37 PM   #8
Something in there is bad.
Old November 13th, 2006, 12:42 AM   #9
new cable, fork, throwout bearing, firewall adjuster, clutch kit, and quadrant
Old November 13th, 2006, 12:51 AM   #10
I'm your huckleberry
Tony_90fox's Avatar
haha, i love that response!
Old November 13th, 2006, 01:25 PM   #11
well then pull the tranny and see if anything falls out
Threads Similar to: Clutch Popping
Popping sound TweederGT03 99-04 4 January 24th, 2007 04:39 AM
Engine Popping shawn91stang 5.0 Mustangs 4 January 7th, 2007 03:50 PM
Engine Popping shawn91stang 5.0 Mustangs 6 December 28th, 2006 08:48 PM
Car Is Popping Out Of Gear 97CobraSvt 96-98 9 November 20th, 2006 10:02 PM
Popping out of 2nd weems Drivetrain 7 October 15th, 2006 11:57 PM
