AOD to T5 conversion
Old November 11th, 2006, 09:42 PM   #1
5chargedliters's Avatar
5chargedliters is on a distinguished road
Im planning on converting my aod tranny to a t5. anybody done this? im pretty much just looking for anyone who might know what kind of problems im going to run into here.
Old November 11th, 2006, 10:00 PM   #2
83 5.0's Avatar
83 5.0 is on a distinguished road
Check the 5.0 sticky Tech articles at the top of this forum, it is a guide I used and was pretty well bang on.
Try and get everything at one time, bellhousing, flywheel, flywheel bolts, drive shaft (automatic should work) clutch pedal assembly, clutch lever cover etc. as I didn't and trying to source all these little pieces took alot of time. Better yet try and find a complete donor car.
If changing clutch cable, get the one that adjusts at the firewall, saves alot of crawling under the car to get it right.
You will need to wire the neutral lock out and back up lights, my connectors were not the same so I had to do some wire tracing.
Good Luck
Old November 11th, 2006, 11:43 PM   #3
Good Luck
thanks ill take your advice on that.
If your not boostin.. your not havin enough fun.
Threads Similar to: AOD to T5 conversion
2v to 3v conversion??? droppedbass87 96-98 26 September 18th, 2010 02:08 AM
conversion Mustang RacR94 99-04 8 April 3rd, 2007 12:02 AM
2.3L to 5.0L conversion stan_doe 5.0 Mustangs 6 January 23rd, 2007 02:39 AM
99-04 V6 To GT Conversion ?'s ineedajob V6 Mustangs 7 November 9th, 2006 05:18 PM
After A 5 Lug Conversion... 347tt 5.0 Mustangs 7 September 28th, 2006 04:53 PM
