what fluid for t5 and how much?
LinkBack (1) Thread Tools
Old June 28th, 2008, 08:30 PM   1 links from elsewhere to this Post. Click to view. #1
swapping a t5 that is completely toasted out of my 88 daily driven hatch with another known or supposely good t5 and wasn't sure what kind of lube is best to run in them or how much.. im thinking it's 2 or 2.5 quarts but would like to know for sure and your opinions on what type of fluid to run in it.
thinking royal purple or synchromesh
Old June 28th, 2008, 08:43 PM   #2
Bandit is on a distinguished road
Well,i run the newer,weaker t-5 not world class but some lucas tansmission fix mixed in with synthetic really seemed to help.I took this tip off a performance shop that does that on all their higher powered stangs so it sounded good to me.Even called lucas and there is no mix problem at all.
I have always felt that the standard fluids did'nt have enough wieght to it for the hotter weather and to hang on the gearing a little better.
Old June 28th, 2008, 11:33 PM   #3
So your saying throw some of luca oil's atf in it?
Old June 28th, 2008, 11:38 PM   #4
TurboLX's Avatar
1988 Mustang LX Turbo
Dexron ATF
Old June 29th, 2008, 06:12 AM   #5
I used 12oz. mixed in a 2.8 qt capacity recommended by lucas as the proportionate amount for my tranny capacity.It's pretty thick stuff.
Lucas Oil
Old July 25th, 2008, 04:37 PM   #6
LTnone is on a distinguished road
Dextron-Mercon ATF is what's recommended by Ford, unless you want some real nice stuff the Dex stuff will work fine. Buy 3 quarts, remove the plug in the side of the tranny (not the drain plug...) and just fill it until it starts dripping out of the hole. It takes just under 3 quarts.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/77975-what-fluid-t5-how-much.html
what fluid for t5 and how much? This thread Refback June 28th, 2008 08:41 PM
Threads Similar to: what fluid for t5 and how much?
how much fluid Thlad 94-95 4 June 9th, 2008 09:57 AM
Fluid Changes Exile 94-95 4 April 2nd, 2008 10:33 AM
T5 Fluid Question 1986GT 5.0 Mustangs 9 February 26th, 2008 03:15 PM
Wiper Fluid Shelby0767 V6 Mustangs 6 February 18th, 2008 11:01 PM
tranny fluid Mustang RacR94 V6 Mustangs 1 April 29th, 2007 10:18 PM
