#21 |
1979 mustang 5.0
hopefully 11's when complete
a 9 second car is usually something that is barely streetable. maybe if you get an 8-71 blower for that 302 and run like a 250 shot of nitrous you'll be in the neighborhood. Now that stock thunderbird 302 block might not like that too much, but you should be able to get one 9 second run out of it....
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
#22 |
darrell=GOD so listen to him
85 svo. work in progress
#23 |
I wouldn't go that far. I have alot of experience with many different combinations in Mustangs but I am nowhere near the god status level.
#24 |
1979 ford mustang
well, i am ase certified engine and emission specialist. i have my whole life dug into automotive. i had a 1988 88 oldsmobile with a 454 and a 2 speed powerglide and a ford f-250 1975-1978 9" stock housing (yes i did break it a couple of times) that was running 8.7 too 9.4 on the 1/4 mile i had around 5-6 grand in the engine.about 2k in the rear diff. the only really expensive thing was the power glide at 6.5k. so i think i now at least something about what im talking. also i just got a 1996 v-6 mustang with a bad,bad miss one the passenger side.
my 1979 october 9th fox body mercury capri.i've gone through 4 engines now. ![]() my capri is for sale. contact me at: bluedragon130@hotmail.com |
#25 | |
95 Lightning-Twin Turbo
10.66@126
'95 Lightning-842rwhp/936rwtrq pumpgas ![]() Twin T-70 Turbos 393w stroker(stock block) TFS CNC heads Cam Motion Custom Grind Hyd Roller cam BBRC EFI Spyder intake FAST Stock 185,000 trans(PI3000 converter,PUNISHER VB) Drag Radials always |
#26 | |
10.66@126
If you are going to try and talk fast to guys that have been fast for many years you should at least do more homework on what parts are used and some prices close to what each set of parts would cost!!!!
#27 | |
That car is way to heavy for a powerglide + horsepower and 8.70s to 9.40s is a real big spread. I don't think I've ever seen a car that inconsistent. I call bs.
#28 | |
Owned!
He keeps digging his hole deeper and deeper.......
#29 |
1986 lx notch
9.98 @ 135
I believe he's been 8.7 - 9.4 .................... in the 1/8 th > : 0 )
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
Threads Similar to: engine swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
| Engine swap... help please!!! | 01stang232 | 99-04 | 5 | April 9th, 2007 09:33 PM |
| Engine Swap | thewayshemoves | 99-04 | 4 | December 25th, 2006 09:58 PM |
| Engine Swap | mnky 99 gt | 99-04 | 2 | November 9th, 2006 10:43 AM |
