engine swap
Old June 29th, 2008, 04:25 PM   #1
blackdragon's Avatar
1979 ford mustang
blackdragon is on a distinguished road
engine swap
ok, i have a 1979 mecury capri witha 200c.i.d. straight 6 i also have a 1993 ford thunderbird with a 302. i know i will have to get motor mount and throttle cables and a bellhousing. but what else will i need to make sure that the ngine will fit in the engine bay fine with no problems? will the computer work fine? will the powersteering need to be changed over? will i need the old alternator or the 302 one? probly the302 on that alternator lol. and should i go out and grab a set of sub frame connectors? after i have fun with this 302 for a while im gonna beef the internals up ALOT.and throw on a supercharger (on top of intake type) thanks and i hope i can get some help off of this.
my 1979 october 9th fox body mercury capri.i've gone through 4 engines now.
my capri is for sale. contact me at: bluedragon130@hotmail.com
Old June 29th, 2008, 06:26 PM   #2
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
going carbed ?if so get a dist for a 1985 mustang, the 93 t bird motor is a roller motor and the 85 dist has the correct dist gear, however the firing order for the motor you have isn't the same as a mustang h.o. you can either change cams or use the t birds firing order.
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old June 29th, 2008, 06:54 PM   #3
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
oil pan too obviously...... If i were you I'd get all the accessory brackets of a mustang 302 as well.....
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old June 29th, 2008, 07:46 PM   #4
1993 mustang lx convertib
saldoggs is on a distinguished road
i would check and see if the lower k frame will accept the v8 i heard that in in line sixes had a different k frame you might be able to use the one from the t bird because it is a fox style chaise
Old June 29th, 2008, 08:34 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need to change the k-member to a V8 or 4 cylinder k-member. Most of the rest will depend on whether or not you are using EFI or not and some other items will have to be done on a trial and error basis like accessories and brackets.
Old July 1st, 2008, 03:17 AM   #6
1979 ford mustang
ok i went too a shop and they said for the k member all i need to do is change the front springs and the spring rate. the oil pan will be a new 5 quarts nickel plated. the efi is a very big posibility. also the accesories will only iclude alternator , and power steering. this car will be a 9 second car very soon.... 550 horsepower roush crate motor is due in 4 months. they have a huge backorder. also should i change the gears in my rear diff? it has 3.83 right nowor was it 3.73 i will look into that. can i use the t-birds distributor? why and why not? i have a 3 inch cowl induction for it too. also if i had the extra money i would buy the new 34 pound tubed k member alot better then a 107 lbs.
Old July 1st, 2008, 09:10 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The shop you went to obviously has never done this swap. You will need a different K-member. The inline 6 k-member will not work with a V8. I guess you could take their advice and learn the hard way...
A 9 second car very soon???? How do you figure. 550 horsepower won't even get you close. Do you understand the work that is involved in a 9 second car? I don't think you do because you wouldn't be talking about buying a tubular k-member if you had extra money and you wouldn't be messing with a stock rear end. You wouldn't be messing with a t-bird engine either, you would have this car off to the chassis shop for a roll cage and chassis work while your engine and trans is being built. I think you need to re-evaluate your goals in a realistic manner.
Old July 7th, 2008, 03:51 PM   #8
1979 ford mustang
ok, i have a custom Tk5 with a short throw shifter, also have a 1 ton rear end that has 3.77 gears. it is installed and is doing fine. the t-birds engine went to my locale machine shop. im getting the deck leveled and getting the engine plasma pressure tested.the rear end is a 9" by the way. the old 8.8 was starting to howl.also im gonna go carbed.
Old July 7th, 2008, 09:08 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Defined custom TK5??? Don't Dana 60s come in 1 ton trucks???
It doesn't matter if you have an 8.8 or a 9", either way you are going to stick several thousand dollars in the rear end to hold the horsepower required to run 9s. You will have a few thousand tied up in the transmission, bellhousing, flywheel and clutch set up as well.
Old July 15th, 2008, 03:27 AM   #10
1979 ford mustang
yes, i have about 4k into the rear. the tranny is a tk5 with custom hardened gears and syncros. i dont know the full details in the tranny (had a shop build it for me). the engine is awsome i built it by hand. the rear ens is out of a 1976 ford f-250.is has been cut down to fit in my car.
Old July 16th, 2008, 12:48 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You are going to need alot more than hardened gears and an F250 rear axle to hold the horsepower required to run 9s. If you truely have an F250 rear axle it will take so much power to turn that heavy thing that you will probably never reach your goals. 3/4 ton trucks have big rear ends with big heavy axles, gears and center section. Not even close to ideal for going fast.
Old July 23rd, 2008, 06:57 PM   #12
1979 ford mustang
lol, you sir apparently dont know the pottential in the 5 lug ford 9" cause even chevy lovers are using ford 9". also as i said i have a little over $4,000 into the rear diff alone. about 10.5k in the tranny. and about $7k in the engine. im in this setup really deep. this car will go under 9 seconds on the quarter mile. so i think you are going onto wikipedia and looking up stupid stuff ppl have posted there or you are listening to some half witted mechanic (no offense to you).
Old July 23rd, 2008, 07:10 PM   #13
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
uh o
Old July 23rd, 2008, 07:14 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ +10
Darrell knows and builds his own shit. I would listen to his advice.
Old July 23rd, 2008, 07:15 PM   #15
1BADSTANG's Avatar
i actually got scared for black dragon.. still am quite frankly.
Old July 23rd, 2008, 08:20 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've never seen an F250 with a 9". F250s have full floating axles and huge rear ends. F150s have 9" rear ends. I am well aware of the abilities of a 9" but big horsepower cars don't use factory housings. Why don't you list the parts that you have in your rear end and transmission. Unless someone gave you half of the parts, a $7000 engine isn't going get you anywhere near the sub 9 second area. If your lucky and your car is really light, it might get you in the high 9s.
As far as your stupid comments about wikipedia and looking up what other people post and listening to some half witted mechanic goes, I find great humor in that. I'm an ASE certified master technician and worked in the industry for years. I've also been drag racing for the past 15 or so years. I know a thing or two about this stuff and probably have forgotten more than you know. So like I tell the rest of the young punk smart asses out there that know everything, its your car and you can do whatever you want to it. Just don't whine and cry when others are going faster with less money in there combinations.
Old July 23rd, 2008, 09:13 PM   #17
1BADSTANG's Avatar
Hes not lying he basically told me that like 5 times and i didn't listen to him, ended up biting me in the ass.
Old July 23rd, 2008, 11:02 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Don't feel bad. I think we all learn the hard way sometimes. I did that when I first started racing. I knew what I needed, the guys that were telling me the opposite didn't know anything because car craft and every other magazine out there told me everything I needed to know.....Lessons in racing....
Old July 24th, 2008, 04:10 PM   #19
1BADSTANG's Avatar
You always say its easier to do it right the first time, usually people just go the cheap way and then they wish they did it right the first time lol.
Old July 24th, 2008, 10:51 PM   #20
86_Notch's Avatar
1986 lx notch
9.98 @ 135
Cheap , Fast, Reliable Pick 2
Threads Similar to: engine swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
Engine swap... help please!!! 01stang232 99-04 5 April 9th, 2007 09:33 PM
Engine Swap thewayshemoves 99-04 4 December 25th, 2006 09:58 PM
Engine Swap mnky 99 gt 99-04 2 November 9th, 2006 10:43 AM
