Lower Control Arm Bushings
when i take off or jus pull off from a light i kind of hear a pop coming from the front driver side of my car.. i think its the lower control arm bushings goin bad...
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
Are the sway bar end link bushings good?
![]() Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats |
Sway bar bushing
Tie Rod end lind Tie Rod inner link (inside the rack housing) Balljoint Ive also seen severly worn/loose brake caliper sliders/pins that would allow the caliper to clunk back and forth with the rotor.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
RLY SRS
I have had a rear shock break and it made a sound like that...
Check the shocks as well... |
Threads Similar to: Lower Control Arm Bushings
| lower control arm bushings | noppe180 | 96-98 | 5 | November 7th, 2007 07:09 PM |
| control arms or just bushings? | crappy_head | 99-04 | 2 | September 15th, 2007 06:51 PM |
| Control Arm Bushings? | CMcD 5.0Lx93 | 5.0 Mustangs | 5 | August 8th, 2007 01:37 AM |
| Rear control arm bushings | Stangzilla | 5.0 Mustangs | 7 | June 2nd, 2007 01:50 AM |
| control arm bushings | angermgt | 5.0 Mustangs | 5 | May 15th, 2007 08:30 PM |
