Mac Exhaust Tail pipe clearance to upper control arm problem
Old November 12th, 2006, 11:25 PM   #1
83 5.0's Avatar
83 5.0 is on a distinguished road
Installed a MAC7995 exhaust on my 83 convertible but no matter how I adjust the muffler and tail pipe, it either hits the frame or rubs the upper control arm. I've bashed the pipe as much as I want to, which has helped.
It seems to hit the bent lip of the control arm, do the after market upper control arms give better clearance for the exhaust, since it looks like they don't have this lip?
Thanks
Old November 12th, 2006, 11:42 PM   #2
you might have to go with dumps if its that bad, but you could probably get a shop to bend it how you need it
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old November 12th, 2006, 11:43 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
get rid of the upper control arms and get a pan hand bar and some sub frame connectors
Old November 13th, 2006, 08:06 PM   #4
83 5.0's Avatar
I was hoping not to have to chop the pipe, and re weld it. Was looking at suspension upgrades anyways, may try that first . Looking at the on line control arms that extra 3/8" is all I need.
Where does the Pan Hard rod connect to? I only remember seeing them on old LTD's if I am thinking of the same part?
Thanks
Old November 13th, 2006, 08:25 PM   #5
HMUSN's Avatar
iTrader: 9 reviews
it connects to you frame and lets you launch at about 3-4 k without breaking tracktion
Old November 13th, 2006, 08:56 PM   #6
Jojogunne's Avatar
1984 GT
13.21@104.61
Jojogunne is on a distinguished road
Re: Mac Exhaust Tail pipe clearance to upper control arm pro
Thanks
Dude ... I feel your pain. I have a MAC exhaust system and every time I go over a bump I hear this loud Clank. My car is lowered with Eibach Sportsline and has Steeda Upper and lower control arms. I have tried many things with out success.
My next attempt with be to move my fuel lines so I can raise my pipes a little higher.
I have steel upper control arms which are wider then the Aluminum lowers. ( I didn't have enough money for aluminum uppers.
Best of luck ..... I will keep following this post perhaps we will both find an answer.
jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over.
Old November 16th, 2006, 11:47 PM   #7
83 5.0's Avatar
I tried raising the mufflers but it just moves it into the frame rail more, the bend of the tubes (2.5") just seems to not be enough. I can make it miss everything, but the hangers slip a little in the rubber isolator and after a few good bumps it's hitting again. May need to weld some stopper on the muffler/pipe hangers to set it for good. ARGHHH!
Old November 17th, 2006, 12:51 AM   #8
Bill is on a distinguished road
take it to an exhaust shop. im sure they can figure it out so it wont hit anything. back in the day i had problems with fitment of my Mac Shorty headers and the mac H pipe. took some Fab work for it to be right.
take it to someone and see what they say
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old November 17th, 2006, 09:09 AM   #9
Stangzilla's Avatar
Stangzilla is on a distinguished road
I have a Flow Master exhaust and it does not hit with my aftermarket Dugan arms. It allowed me to adjust out the clanking noise. You are like the 10th person that said in this forum and others that had trouble with MAC exhausts. I dont know if they are bent a little different than MAC or if its the brand of arms they are runnin.....sucks man....
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Threads Similar to: Mac Exhaust Tail pipe clearance to upper control arm problem
Should I Replace My Upper Control Arm Faulconer 2005 - 2010 6 June 14th, 2007 12:59 AM
Anyone got BBK Upper and Lower Control Arm. stang94 94-95 3 April 25th, 2007 12:17 AM
Upper & Lower Control Arm stang94 5.0 Mustangs 5 March 14th, 2007 07:21 PM
Upper and Lower control ARM? stang94 5.0 Mustangs 9 December 6th, 2006 11:39 AM
Clearance Problem Josh92 5.0 Mustangs 18 November 9th, 2006 07:41 AM
