Discussing Help with Fox 5.0 351 recent engine swap... in the 5.0 Mustangs Forum. Ok.. heres my story... I recently installed a 5.8 in my 89 5.0 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Help with Fox 5.0 351 recent engine swap... ) HERE'S what I found....I think....During my build I installed a new Billit MSD distributor. I know the electonic spark module on the side of the distributor has been a design issue since day one.. with reguards to heat. I put my finger (or rather tried) the side of the electronic piece was WAY WAY WAY to hot to touch....I managed to pop off the little door on the side... then.. I think I saw the problem...the gel or whatever they put in there.. was VERY moveable. The whole distributor was a bit hot.. but the electronic module was VERY VERY hot. Can any and all chime in?? Has this remotly happen to anyone else on here...I was thinking about relocating the electronic module to the firewall...is there a kit... I'm pretty confident I can rig it to do it myself.. but.. wanted to get the thoughts here...does that even sound like my problem?I ended up calling my mom... yes.. my mom (watching the kids).. had her pick us up (4hrs later) then went back with my trailer that same night 4 more hrs later loaded the car, then jumped into the back seat of the truck to get an hour or 2 of sleep.. then.. back home.. 3 more hrs...uhhg.. long night/early morning. I actually have pics... and got to meet a bear.. in the pass.. with the sun just cresting the Mtn tops...It was just me.. the snow.. and the outhouse.. I just visited... Thats an interesting story in it self.. I was out of the truck at the time..... ANYWAYS>... THOUGHTS? Last edited by Washington5.0 : July 2nd, 2008 at 09:24 PM. |
#2 | |
1987 ford mustang gt
well see when shes done
1986 lx notch
10.78 @ 124.96
that happened to me twice ( different cars ) , both times it was the fuel pump
vids of my car the raggedy car you hear is the nova, he's running open headers and it's drowning out my car http://www.youtube.com/v/P3-7Oobydyo&hl=en http://www.youtube.com/v/rmPPnfHZ9WA&hl=en http://www.youtube.com/v/HcD354133Ac&hl=en |
When is the last time you changed the fuel filter? Also where did you get your gas? Typically when it comes to issues with the ignition mod, it straight dies if it or the pickup in the dist are shot. When it sits long enouph to cool off, may start and run then die when it gets hot again. I didn't have any middle ground.
My first Stang, 68' Coupe, 289ci C4, and 68102 original miles. |
1989 LX Vert - 1993 Notch
Fast
Mine used to die when hot too. Was finally tracked down to bad coil
Get rid of that MSD dizzy. Bet you have an MSD or other after market coil too? I had nothing but problems with mine. Personally I'll never buy MSD again ....... same goes for coils. MSD distributors are CRAP Put Ford Motorcraft distributor AND coil in.
#6 | |
1989 Mustang LX
10.98@126.7 NA
My first thought was fuel related problem as well, bad pump, crap in the tank, blocked fuel filter, etc.
Never fast enough.
I did have a passing thought about the fuel....and it did start happening after I filled up at a Safeway in Enumclaw (they had issues weeks before about water in the tanks of several Safeways...and causing similar issues with other cars...BUT, I thought that was resolved by then. Maybe not. I cant remember... but....the fuel pump is in the tank....right? time to drain the fuel...????
My car does that all the time in the summer. in the winter I can drive anywhere but once it gets in the upper 80's and 90's I wont drive it over 20 miles.
I have replaced the ignition module. did the same thing. I replaced the thermostat last fall. the old one was in pieces, but I havent taken the car on a long summer drive yet so who knows. I am thinking its the fuel pump as well. I replaced the fuel filter last spring and since my fuel gauge dosent work I plan on replacing the pump the same time I replace that fuel level arm.
FREE LUNCH, FINAL WISDOM, TOTAL COVERAGE... WHY NOT?
1990 hatchback lx
your fuel tank maybe building up pressure if the evap is not working properly. it needs to purge off pressure to keep the fuel pressure regulated properly.
www.moultondragway.com |
#10 | |
1989 Mustang LX
10.98@126.7 NA
Never fast enough.
#11 | |
Washington, sorry don't mean to hijack ur thread, but TWIST IT UP- does the pressure above the fuel in the tank actually effect the pressure at the regulator? Last edited by SALIV8 : July 3rd, 2008 at 05:07 PM. |
I just had a hell of a day with this shit. I went 116 miles doing that exact same thing. if you seen a guy beat the hell out of a pay phone at 71 and 7 hwy....that would be me. It died on me about a 1/2 a mile from a flying j truck stop and I walk in about to pass out from the heat sweating my ass off and I have to basically yell at the staff for some water. some other guy was there and wated an hour and a half for a hamburger.
Then I get home and I order a pizza because Im sun burned and exhausted and dont want to cook. I order a pizza and wings, they forget the wings I call them and they said they will get them right out to me. 2 hours go by and I call them again. and some how someone played the stoopid card and made them for carry out. All in all a very fucked up day with everyone stuck on stupid.
I found this page that might be able to help you out
and me
1986 LX
none yet
sounds like the TFI (thick film integrated) module almost for sure. but some of the symptoms of that can also be the same for the bad fuel pump or also a cruel trick someone could have pulled with a marble or something of the sort. some people say it doesn't work but I know first hand that it does. and it sucks. swap the tfi and see if that fixes it. if not, check your fuel flow. good luck!
#15 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Threads Similar to: Help with Fox 5.0 351 recent engine swap...
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| 351 swap | djh1286 | V6 Mustangs | 46 | February 26th, 2008 11:13 PM |
| 351 fox front springs | saldoggs | 5.0 Mustangs | 4 | February 5th, 2008 12:02 PM |
| 351 Swap | FranMan | 5.0 Mustangs | 63 | December 22nd, 2007 11:35 PM |
| When a free engine isn't free...Big Block/Fox swap? | 1/4-horse | 5.0 Mustangs | 7 | February 27th, 2007 06:05 PM |
