Signal Flasher?
Old November 13th, 2006, 01:30 AM   #1
slingblade05 is on a distinguished road
Signal Flasher?
i have a 1990 mustang and i was wondering where the signal flasher is located as my signals dont work
Old November 13th, 2006, 01:31 AM   #2
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Should be in the fuse box...
A big round metal looking thing...
Facebook
Google+
Old November 13th, 2006, 01:36 AM   #3
thats the emergency flasher which is separate
Old November 13th, 2006, 01:38 AM   #4
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Is it both of them? Are you sure the flasher is out?
If one of the bulbs is out the turn signal wont work...
Do you have a Chiltons? Or some kind of Repair Manual?
Facebook
Google+
Old November 13th, 2006, 01:43 AM   #5
the bulbs?
theres no clicking and the signals on the instrument cluster dont work
Old November 13th, 2006, 01:44 AM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Yeah when you have a bulb go out the dash wont flash and nothing will click...It will just light up the arrow...
Check you bulbs to see if they are even lighting up...
Facebook
Google+
Old November 13th, 2006, 01:46 AM   #7
absolutely nothing works when i click the signals both ways
Old November 13th, 2006, 02:00 AM   #8
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
So the turnsignals outside the car dont even come on?
Facebook
Google+
Old November 13th, 2006, 02:05 AM   #9
nope nothing
Old November 13th, 2006, 02:14 AM   #10
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
When did this happen?
I am trying to find an online repair manual becuase that would solve your problem...But I ahve not been able to find one...
Facebook
Google+
Old November 13th, 2006, 02:21 AM   #11
thanks, well the horn doesnt work either, it happened after i took the steering wheel off to change the clock spring i think
Old November 13th, 2006, 02:22 AM   #12
yeah, you must have unhooked something else too.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old November 13th, 2006, 02:28 AM   #13
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
You should get an repair manual...Sounds liek you eithe rblew a fuse or did not hook something back up...
Facebook
Google+
Old November 13th, 2006, 02:31 AM   #14
so it couldnt be the flasher?
Old November 13th, 2006, 02:33 AM   #15
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
It could be but since your horn is not working as well I would say it is a fuse or you did not hook something back up...
If it was just the signals then I would say it could be the flasher...
Facebook
Google+
Old November 13th, 2006, 02:37 AM   #16
i think the horn was after though
Old November 13th, 2006, 02:40 AM   #17
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
So did it all work before you took it apart?
Horn and Turnsignals?
Can you flip your high beams on and off?
Just trying to see if the switch is working at all on that lever...
Facebook
Google+
Old November 13th, 2006, 11:20 AM   #18
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I had a hell of a time finding mine. mine was on the back of the fuse box I channged it nothing happend then I had to lay down on my back and look under the dash(way up there) to the bolts holding the fuse box you might see another flasher. mabey blue or silver. hope this helps
Old November 13th, 2006, 02:28 PM   #19
OTreborO is on a distinguished road
woooooo woo
E-Flashers are on thr Fuse Box, Turn signal Flashers are behind the radio, on a bracket, usually Blue plastic.
I would say one or more of your wires is loose on the back of the steering columb.
There are 3-4 harnesses that plug into the steering column. I was having a prob with my turn signals and I found out that the plastic harness had a broken tab that was allowing the wire to not properly seat. I just crimped the wire, and made it grip a little tighter for now. I will eventually get a new entire plastic harness assembly. I would check all of the wires and harnesses on the steering column. Sounds like 2 of them are loose to me
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old November 14th, 2006, 02:39 AM   #20
thanks guys
Threads Similar to: Signal Flasher?
Turn Signal Flasher Location ridebmxfbm 5.0 Mustangs 22 May 23rd, 2010 01:03 AM
Turn signal flasher wrenchbender Audio/Video 0 October 22nd, 2007 07:04 AM
livewire flasher sugnyte69 General Tech 1 April 17th, 2007 10:27 PM
turn signal flasher slingblade05 5.0 Mustangs 5 January 1st, 2007 07:38 AM
sequential turn signal flasher 99mustang232 Visual 1 February 10th, 2006 09:48 PM
