Discussing Stock '93 5.0...is this a good cam? in the 5.0 Mustangs Forum. My car is stock except for JBA headers. I am going to upgrade the intake ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Stock '93 5.0...is this a good cam?ford racing b303 roller cam. Intake Duration at 050 inch Lift: 224 Exhaust Duration at 050 inch Lift: 224 Duration at 050 inch Lift: 224 int./224 exh. Advertised Intake Duration: 284 Advertised Exhaust Duration: 284 Advertised Duration: 284 int./284 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in. Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.480 exh. lift Lobe Separation (degrees): 112 |
1993 Lx
13.58@104.09
b cam is good but you wont notice much of a gain without heads, my cars getting a trickflow stage 1 in it now ill let you know how i like it in 2 days
Mac cai, thats it for now Cowboys 4-2 |
1987 ford mustang gt
well see when shes done
even with heads that cam is not going to net you much of a gain.
93 GT Hatch
12.68@112.57
if you are goin with a gt40 intake then it should be a nice little cam for a mild build up. it is older technology now most people get the trick flow stage 1 cams for there mild build ups, better cam and better technology, and i beleive a little cheaper.
http://www.geocities.com/vz_one/superman5.jpg |
90 lx hatch
13.02@103.62
If you do a h,c,i swap that cam should be perfect. I'd use the afr 165, that will be best with that b-303 cam make good low end torque probably run some 12.10s or so on motor. But that is a good cam to start with. GOOD LUCK!
to many parts and money to be so slow ![]() F/S 1986 mustang vert asking $6500 http://www.moddedmustangs.com/forums...ml#post1277818 |
Thansk for the responses. I guessI am going to wait for a differnt cam and save money for the AFR 165's.
I forgot to mention that this '93 5.0 is in a Mazda Miata so 12.10's...maybe.... |
93 GT Hatch
12.68@112.57
i ran in to a miata the other day with a 5.0 in, it was pretty bitchin
88 Gt
not slow
i have been lookin for a while for plans and engine mounts for this swap... got any info?
88 Gt
not slow
what drive shaft did you use?
#10 | |
1993 Lx
13.58@104.09
dam makes me wish me and chris finished his project, we were putting a 5.0 in a first gen rx7 but he lost interest
I would use trick flow stage 1 cam summit has them and there cheaper than the frpp 303 cams...... and in my opp better but if you want a 303 I would go f cam good luck either way you go
1983 mustang lx
hes runnin out of gear
1983 mustang lx
ah yup. his other rx7 with the 327 police intercepter motor reaches 150 very quickly as well.
and i think the rear in the 302 rx7 is stock, only 1 tire fire. so i dont know whats up with it |
Threads Similar to: Stock '93 5.0...is this a good cam?
| Cam for a mostly stock 5.0 ? | blakehunter316 | 5.0 Mustangs | 40 | May 24th, 2008 03:54 PM |
| is this a good cam? | tigerfan2771 | V6 Mustangs | 15 | April 23rd, 2008 12:14 AM |
| With A Good Cam... | blue03mach1 | 99-04 | 5 | December 5th, 2007 09:22 PM |
| Stock Cam | cali 5.0 | Modular Mustangs | 1 | November 7th, 2006 02:00 PM |
| Looking for a good street cam!! | 1bad04gt | 99-04 | 2 | October 23rd, 2005 04:09 PM |
