Mustang Convertion
Old November 13th, 2006, 09:52 PM   #1
doorvip is on a distinguished road
Mustang Convertion
whats up guys and girls new to the site i have a 88 mustang lx i want to convert my 4 lug to 5 and my rear drum to disk....what i have is a complete rear end out of a 87 Lincoln mark vii ....can i have the axles shortened and use all the brake hardware to make this work ???? also im trying to use 18" billets wheels 5 lug i dont think i can use the front rotors from the Lincoln mark because the dust cap will stick out to far dose anyone know if this is the case
HELP
Old November 14th, 2006, 10:42 AM   #2
mdvaldosta's Avatar
11.47@120.58
For the front:
-For the 79 v8, 82-86 Mustangs, and 87-93 4 cyls, you can use the 4cyl 83-88 Ranger rotors.
-For the front 87-93 v8 cars, use the rotors from a mid 80's Lincoln Continental, Lincoln Mark VII (85-91), or '84-'86 SVO. For the 79-86 and 87-93 4cyl cars, use the 83-92 4cyl Ranger front rotors. This will keep the cost down and allow you to keep the stock front brakes. You can buy the rotors for about $40-60 each. You an also purchase after market front rotors like the Power Slot brand in 5 lug. These cost about $99 each.
For the rear:
To keep the stock rear wheel offset and drums, the '83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32") is what you want. They are the same rear axles, the center section is just on the opposite side when you compare the rear ends. The pumpkins are also off center unlike the Mustangs, so you will have to find two vehicles to pull axles from! You will need the drums from either of these vehicles also if you are staying with rear 9" drums. The 7.5 axle Rangers & Aerostars use 9" drums. These parts are direct 5 lug replacements for the stock 9" rear drums on the 79-93 Mustangs.
This is taken from a really good resource I found online, read this for the rest of the article.
Threads Similar to: Mustang Convertion
2001 mustang 5 speed vs. 2005 mustang auto. DannyStu Drag 20 October 6th, 2007 10:55 AM
1988 Ford Mustang GT Convertible Mustang Problems ridebmxfbm 5.0 Mustangs 18 May 14th, 2007 01:35 PM
4 To 5 Lug Convertion And Rear Disk doorvip 5.0 Mustangs 0 November 16th, 2006 05:11 PM
