Discussing Violent Shake Common? in the 5.0 Mustangs Forum. I have a 90vert 5 speed, Normal bolt ons, heads cam intake and gears... I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Violent Shake Common?So question is..... Is there also other COMMON shake issues I should know about? Thanks
the uhh transmission mount could be bad or even the motor mounts.. what part of the car do u think its coming from??
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
check you timing
well shit this town aint big enuf for the both of us |
I had a shake in my car but i have new urethane motor and tranny mounts good gears with a locker and new 31 spline axles. After rebalancing all my tires I replaced the stock driveshaft with a new aluminum one and the vibration went away... not sayin that is your prob but that is what happened to me...
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
i had one when it rained but i replace the dist. cap and rotor and no more problems.
Suck on it Trebek. Suck it long, suck it hard.
The Cable Guy...
SLOW
I had the same issue in my 91...
It ended up being the drive-shaft was not balanced... I bought a new drive-shaft and it fixed it... |
where would you get your drive shaft balanced and how much does that cost
92 notch project ..new plans.. 2.3l turbo anyone with 2.3 block or complete motor lyin around pm pleaseeeeee(someone in the new england area)
#8 | |
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
I just bought a new Ford Racing alimunum shaft. I needed one anyway because of the amount of power my car has. I have no idea how much or where you could get that done.
The Cable Guy...
SLOW
Yeah I just went and bought a new drive-shaft...
A local auto shop had a drive-shaft balancer and they checked it and my drive-shaft was all kinds of out of balance... |
Threads Similar to: Violent Shake Common?
| Wheel shake | MustangMatt | 2005+ | 9 | October 6th, 2007 10:17 AM |
| Common guys | Juggalo_X | The Clubhouse | 19 | September 5th, 2007 06:38 PM |
| Is This Common? | mustangmanic | 99-04 | 17 | July 7th, 2007 04:49 PM |
| Ping I cant shake | Juggalo_X | The Clubhouse | 30 | June 22nd, 2007 08:59 PM |
| Overheat and Shake! | TorqueMonster | V6 Mustangs | 4 | August 19th, 2006 08:25 AM |
