Exhaust Question
Old July 7th, 2008, 10:48 AM   #1
1sl0w88's Avatar
88 LX 5.0 Convertable
1sl0w88 is on a distinguished road
Exhaust Question
Hey Guys!
Its time to replace the exhaust in my 88 convertible. I was thinking of going with a set of equal length shorty headers, off-road h-pipe and turn downs instead of going all the way out the back. In doing this is there any kind of issues that I need to be concerned with? The car is Speed Density and bone stock except for under-drive pulleys and the smog pump being by-passed.
Robbie
_________________
88 LX Convertible 5.0
84 GT - Project
66 F100
Old July 7th, 2008, 11:08 AM   #2
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
you shouldnt see any problems with that setup
Old July 7th, 2008, 02:26 PM   #3
1sl0w88's Avatar
Good! I was just wondering if there would be any problems without the cats.
Robbie
_________________
84 GT - Project
66 F100
Old July 7th, 2008, 02:41 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
You mean turn downs after the mufflers? Either way, it is loud and you will have some exhaust smell in the car.
Old July 7th, 2008, 02:45 PM   #5
Smirnoff's Avatar
1982 GT t-top
nope you dont have any sensors after the cats
and my exhaust is dumped after my muffs and i dont really get any exhaust smell in my car, its just a smidge louder inside than with exits
Old July 7th, 2008, 04:45 PM   #6
1sl0w88's Avatar
What about the current sensors? I wont be able to hook them up with the h-pipe so what do I do about them?
Robbie
_________________
84 GT - Project
66 F100
Old July 7th, 2008, 04:50 PM   #7
91cobra5.0's Avatar
98 Cobra
your gona have to run some type of muffler, its loud as all hell without cats, i just recently did mine and tried to run without mufflers and it was too loud, like get pulled over within 5 blocks loud
Old July 7th, 2008, 04:59 PM   #8
1sl0w88's Avatar
Im sorry. I didnt make that clear. I meant turndowns after the mufflers.
Robbie
_________________
84 GT - Project
66 F100
Old July 8th, 2008, 01:26 AM   #9
fogged306's Avatar
89 GT
If you're talking about the o2 sensors, there will be bungs welded into the h-pipe for them, you just re-install them just like they were.
Old July 9th, 2008, 07:10 PM   #10
1989 ford mustang lx 5.0
lets find out?
89lxroadburner is on a distinguished road
i run offroad pypes set-up on mine with a x-over & i have had no problems...actually i dont think i have it in me to put cats on...lol
Old July 10th, 2008, 08:50 AM   #11
1sl0w88's Avatar
Thnx for the help. I just didnt want to run into any more problems than necessary!
Robbie
_________________
84 GT - Project
66 F100
Old July 10th, 2008, 09:08 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No tailpipes is alot louder inside and outside of the car no matter what muffler you use. Not to mention the exhaust gasses that will be inside the car on a daily driven vehicle. No tailpipes has absolutely no performance benefit so why do it? If you want a performance increase take the entire exhaust system off. Quiet cars that are fast are cool.
Old July 10th, 2008, 01:11 PM   #13
1sl0w88's Avatar
Yeah, I agree about it being louder inside the car. I guess my question was really more about the o2 sensors if I put an after market h-pipe on it. I just have to watch my cash flow right now. Several other things need attention too. The trans just started to grind a little going into 2nd if the rpm's are up and I deff have a broke ring or two in the #8 cylinder. I have an extension on the plug to keep it from fouling out. Uses way too much oil. But, I still have plenty of power and get good gas mileage. 20 to 21 mpg.
Robbie
_________________
84 GT - Project
66 F100
Old July 10th, 2008, 02:04 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The oil consumption is probably valve guides or valve seals.
Old July 10th, 2008, 02:11 PM   #15
1sl0w88's Avatar
Seals have been replaced. The reason I say cracked rings is bacause the plug in #8 gets covered in oil. But this could be caused by the guides?
Robbie
_________________
84 GT - Project
66 F100
Old July 10th, 2008, 02:32 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Bad guides or seals will cover the plug in oil as well. I had an 88 GT that was like that. Once I rebuild the heads everything was fine. Oil drains back thru the heads so it has a direct path to the cylinder if there is an area to leak thru. Sounds like a good reason to put some Twisted Wedge heads on it
Old July 10th, 2008, 02:36 PM   #17
Hunt_chevs's Avatar
2002 Gt
Not Slow
Sometimes my eyes water a little bit from the exhaust in my car,. i aint gonna lie i kinda like it.. i have bbk equals, bbk o/r H, and flows with dumps,... beastly and it sounds purdy
Old July 10th, 2008, 04:38 PM   #18
nolife's Avatar
91GT, 88GT, 02GT
I ran dumps after flows for a while, I got sick of the loud and smell (and I have cats and full emissions). I am back to full exhaust now. Sounds really good outside the car and when i get on it but after about 10 years of Flowmasters on my Mustangs, I think I've finally had enough of the drone.
Threads Similar to: Exhaust Question
Exhaust question + supercharger (warranty) question r00st 2005 - 2010 2 January 31st, 2008 11:07 AM
Exhaust Question usafimj 2005 - 2010 6 November 19th, 2007 02:27 AM
ya another v6 exhaust question...... mustang kid 1989 V6 Mustangs 17 September 11th, 2007 03:01 PM
Another exhaust question scxc15 V6 Mustangs 16 April 19th, 2007 06:31 PM
exhaust question Sam'sWildStang V6 Mustangs 13 February 20th, 2007 09:49 AM
