1988 Mustang
throttle position sensor
What tho wires do I hook the multi-meter to to set it? What should the setting be? Is it volts or amps?
1990 5.0 LX Notch
green and black it is volts, I think it should be about .95.
With Ign On Eng Off, check TPS voltage output....if it's between .8vdc - 1.0vdc, it's OK. This voltage check should be done between the Green and Black wires at the TPS side connector as shown in the pic below (FYI: Green = TPS Signal, Black = SIGRTN, and Orange = VREF)....(-) terminal of the DVOM on the Black wire and (+) terminal on the Green wire. TPS output is within the .8vdc - 1.0vdc range optimum range. Last edited by flamed 98 gt; July 7th, 2008 at 03:05 PM. |
1988 Mustang
Threads Similar to: throttle position sensor
| Throttle position sensor | shurb125 | 5.0 Mustangs | 6 | January 12th, 2008 10:36 AM |
| Camshaft Position Sensor | jagstang96 | 96-98 | 2 | November 16th, 2007 12:05 PM |
| '00 Crankshaft Position Sensor | mbooz02 | 99-04 | 5 | November 8th, 2007 05:24 PM |
| Throttle Position Sensor And Power Adders | stangempire82 | 99-04 | 1 | November 19th, 2006 08:14 PM |
| P0340 camshaft position sensor | yellowfever | 99-04 | 1 | October 9th, 2006 11:19 AM |
