Setting A Goal - Page 2
Old November 17th, 2006, 12:43 PM   #21
cali 5.0 is on a distinguished road
Originally Posted by 95opal
heads cam intake. Typical street kits like TFS, edelbrock or holley, AFR,FTI,eddie combos.
o ok now ur talkin about the engine kits... i thought u meant some kind of ignition or somethin... but yeh i already new tht about the kits, how can i get more with jus all motor
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old November 17th, 2006, 02:34 PM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by cali 5.0
ok so how would i end up getting 350+ without power adders
Good parts and a well matched combo. There is a well known guy on another Mustang site that just made 526hp with a 306 which about 440hp at the wheels thru a manual transmission. He did it with 11:1 compression which will run on pump gas. The difference between a combination that makes good power and one that doesn't is the person designing it. A guy that knows what he is doing will make more power than a guy that copies what the popular Mustang magazines do. That is the benefit of paying good money for a good engine builder.
Old November 17th, 2006, 06:22 PM   #23
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Read what darrell wrote he pretty much gave ya the answer. Its all in the combination of parts. You need to really set some kinda of goal for your car before you do anything. Is it gonna be dd, street strip, strip only, auto x ? What do you want out of the car? These things all play a part in how you set up your combo. Remember peak #s arent the whole ballgame, theres also HP under the curve . You can build a dyno queen and have HP bragging rights. But the same car can get smoked on the street by a combo with less peak hp. I doubt you would want to drive that 306 w/ 11: 1 as your dd, then again you wouldnt want to build a 8:5:1 306 NA and expect great things at the track. Do you understand what im getting at. I just had ED C at flowtechinductions put together a nice street set up for my 95. Now I know this thing will not be a dyno monster but I know for sure it will make some good #s under the cure, cause thats what I wanted a dd with good street maners and usable hp. If i have to rev to 6800 for peak #s it would be useles to me cause my car will never see those rpms. Now if i was building a car for the track the combo would be totaly different. So what Im trying to say is build the car to meet your goals and not so much (I want x amount of hp) cause you can build any motor with X hp, but is that hp where you need it and use it?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 17th, 2006, 10:27 PM   #24
shit i never thought of it like tht, but i want it to be a street car daily driver and still be able to run maybe low 11 on the track. i really got my heart set on a turbo system, but i also want my car to be diff. from all the others tht i seen out here
thx for the advice by the way
Threads Similar to: Setting A Goal
Trying to hit my goal of 300hp...suggestions? 95blackbeauty 94-95 33 January 17th, 2008 08:30 AM
My new goal in life + ridiculous video Phoenixx The Clubhouse 6 October 15th, 2007 12:56 AM
setting TPS wildfaststang 5.0 Mustangs 6 August 27th, 2007 11:47 PM
My Goal is 400 RWHP...tell me what u think StuTheMusicEngineer 99-04 14 March 3rd, 2007 07:06 PM
