Discussing Nitrous question - Backfire vs. Afterfire in the 5.0 Mustangs Forum. Hey guys, ive been working on the stang project and was thinking of putting nitrous ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Nitrous question - Backfire vs. Afterfire |
1986 lx notch
10.78 @ 124.96
stay off the rev limiter and you'll be fine
vids of my car the raggedy car you hear is the nova, he's running open headers and it's drowning out my car http://www.youtube.com/v/P3-7Oobydyo&hl=en http://www.youtube.com/v/rmPPnfHZ9WA&hl=en http://www.youtube.com/v/HcD354133Ac&hl=en |
Editor
Secret In The Works
Good advice ^^
A good way to ensure you dont have any "rev limiter" accidents is using a window switch. Search around on this forum, theres lots of Nitrous threads with tons of good advice and info. Always try to keep in mind that you want to start small, and work your way up. And even though its a pain in the ass to continuously pull plugs, make sure you keep an eye on their condition every few times you spray. The more Nitrous you spray *larger shots*.. the more often you need to check your plugs. Nothing beats being able to read your spark plugs. Even the best Wideband Air/Fuel systems and gauges dont know exactly whats going on in the cylinders. Search around.
Definition of Fast? ![]() I'd say thats good enough. ![]() NMRA Outlaw 10.5 Season Opener 2008 Photo courtesy of - Yours Truly |
Ok will do thanks guys. Also what about wet vs dry shot, i figured a dry shot kit would be better for a nitrous noob like me, i was thinking of the zex dry kit, but what do you guys think? Also i was just really wondering b/c it looks crazy what has to happen to make your care have an afterfire, i saw a vid and it was like a flame thrower coming from the tail pipes. JW. Thanks guys!
Make sure you have plenty of fuel and run some colder plugs.
![]() 03 Cobra-475/441 to the wheels 02 SS-Sold 00 Z/28-Totaled Official Black Terminator Club Member |
Also, dry shots are nice, but for a first timer I would consider a simple wet nozzle. It just seems that keeping an ideal A/F ratio is easier with a wet shot. I know that some tuners don't even touch dry kits so that's something to keep in mind.
Editor
Secret In The Works
Slighty off topic.
rk > You finaly bought a termi??? Its been awhile since ive been on the board. That bitch looks good man!
1990 Mustang LX
9.36@143 mph
I've hit the rev limiter missing shifts in the past and not had any problems with backfires or anything. The main things to consider are using a good nitrous system, following their recomendations and directions, don't spray under 3000 rpm and make sure the pedal is to the floor when you spray. Wet kits on EFI cars that hae a plate between the intake and throttle body are the cause of alot of backfires. The wet kits that put the plate between the upper and lower intake don't seem to have this problem because the fuel and nitrous is sprayed down the intake runners instead of into the upper plenum. Dry kits are very user friendly and very hard to screw up. The dry kit design is simple and works very well. I would also suggest never using telflon tape on nitrous systems. The teflon tape gets caught up in solenoids. Use a small amount of pipe dope instead. I would also suggest taking your soleniods apart at least once a year to clean them out and check everything. They do get crud in them and do need rebuilding from time to time. A sticky solenoid can cause backfires and other problems.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Threads Similar to: Nitrous question - Backfire vs. Afterfire
| Nitrous Backfire | 347stroker | 99-04 | 18 | March 26th, 2008 12:59 PM |
| Nitrous Backfire | CAMN89GT | Multimedia | 7 | December 4th, 2007 07:12 PM |
| nitrous backfire? | N02coupe | 94-95 | 2 | April 2nd, 2007 05:11 PM |
| nitrous backfire | jetmech | Poweradders | 1 | October 18th, 2006 07:57 PM |
| backfire | ttop5.0 | 5.0 Mustangs | 7 | May 17th, 2006 10:25 PM |
