egr spacer with bigger throttle body
hey guys.
I've got a 70mm bbk throttle body i want to install on my 89 gt. it seems as though the EGR spacer is only 60mm or so. should i bore it out? i've got access to a hone that will work. i was also gonna plug up the coolant lines running to the spacer. is this a good idea?
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
1992 Lx
11.39@119.24
if you dont have heads or anything major done that tb is gona slow your car down, gona lose a shit ton of low end
hmmmm... i was told 70mm would be ok on stock. should i wait till i get an intake or cam? is it seriously gonna be that bad on a stock motor? what if i were to put that and an explorer intake on? would that be any better??
1989 ford mustang lx 5.0
lets find out?
70mm sucks on a stock mustang.. u lose a crap load of low end torque. 65 is tha biggest you want to use. if you have any decent mods ...than thats the way to go.
1992 Lx
11.39@119.24
i noticed losing lowend when i just put my 65mm on, just wait till you do heads
#6 | |
1992 Lx
11.39@119.24
A bigger throttle body on a stock 5 liter is a waste of money and will do more harm than good. As far as boring the spacer, I'm not sure if you can or not without running into problems. I don't know if all of them are cast the same or if there are changes in the casting to accomadate the bigger bore. If it was me I would buy the correct spacer or eliminator plate instead of trying to rig something up. Do not plug the coolant lines if you are using an EGR plate. The coolant lines are there to cool off the EGR plate, why would you want to remove them?
Threads Similar to: egr spacer with bigger throttle body
| throttle body spacer | nslinky | 2.3 Mustangs | 5 | August 7th, 2010 09:55 PM |
| Is a bigger throttle body a bad thing? | energiesource | 99-04 | 26 | September 22nd, 2007 04:39 PM |
| throttle body spacer | JASonic | The Clubhouse | 11 | July 18th, 2007 08:46 PM |
| Throttle Body Spacer.... | Mystry | 96-98 | 5 | July 29th, 2006 12:05 AM |
