125 shot nitrous
Old July 8th, 2008, 08:20 PM   #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
125 shot nitrous
Brenspeed has a 125 shot of nitrous wet kit for 5.0's, is nitrous a good bet? I can get a bottle warmer and the other reccomended thing for like 150-200 extra, so it would come out to 720 give or take. Now, I have 24 pound injectors, but i am doing a hopefully 275-300rwhp gt-40P and explorer combo with an e 303 cam. I have all bolt ons imaginable. How would i do? would i need a bigger fuel pump? I dont know if i have a stock fuel pump, i bought the car with the 24 pound injectors and a fuel and oil gauge in the cowl so i bet he has that upgraded, but whatever i will get a new one anyways. I know crap about nitrous so just let me know how i look!
Old July 8th, 2008, 08:33 PM   #2
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
With the WET kit you'll be fine with those injectors. Fuel pump is fine as well, you'll be good for up to 375-400 RWHP.
Nitrous is not dangerous - Dangerous is not having it tuned right.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old July 8th, 2008, 08:35 PM   #3
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
If your running a wet shot than you don't have to worry about your injectors as far as the nitrous goes.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old July 8th, 2008, 08:47 PM   #4
1BADSTANG's Avatar
well i asked brenspeed and he said i dont even need a dyno tune. It wouldn't run correctly without a tune?
Old July 8th, 2008, 08:48 PM   #5
1BADSTANG's Avatar
and i think i will have more than 400rwhp with the nitrous
Old July 8th, 2008, 08:50 PM   #6
1BADSTANG's Avatar
could this be me?
Old July 8th, 2008, 09:00 PM   #7
1BADSTANG's Avatar
i have an 88 gt by the way, 135k with a brand new tranny and a rebuilt engine (supposedly) engine has approximately 20k on it after rebuilt. Any other add ins opinions suggestions anything?
Old July 8th, 2008, 10:14 PM   #8
93 GT Hatch
12.68@112.57
superman5.0 is on a distinguished road
Send a message via AIM to superman5.0
you will need a nitrous tune for sure. i know my boy tampa up there is very experinced with it.
Old July 8th, 2008, 11:58 PM   #9
ryans88gt's Avatar
you will not need a tune if you use the recommended jetting.
There is power to be had from a dyno tune, but the recommended jetting will be very safe.
Old July 9th, 2008, 03:32 PM   #10
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
plenty of people running juice run it without a tune... just remember to retard that timing...
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old July 9th, 2008, 06:03 PM   #11
ryans88gt's Avatar
no need to retard timing with 125 shot as long as you are running 93 octane and have your base timing set at 14 degrees or less.
14 degrees base + 18 advance = 32 total
That is not a lot for a 9:1 motor at all and it can run plenty of nitrous with that timing and decent gas without detonation problems. Just remember to check the plugs and don't rely on your ears to hear detonation.
Old July 9th, 2008, 06:20 PM   #12
1BADSTANG's Avatar
what should i do about the window switch? How should i set it up for street use?
Old July 9th, 2008, 06:32 PM   #13
Hunt_chevs's Avatar
2002 Gt
Not Slow
+1
Old July 9th, 2008, 09:33 PM   #14
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
zex dry kit, put the 125 jets in , set the timing to 12 degrees and be done with it, a bottle heater is a good idea and i've never run a window switch . stay off the limiter and you'll be fine
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 9th, 2008, 10:18 PM   #15
1BADSTANG's Avatar
woah why do i want the dry kit now?
more input, why dry?
Old July 9th, 2008, 10:28 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Dry kits are very user friendly and very safe. I call them "beginner kits" because of their friendliness. No matter what kit you get I'd make sure you have a bigger than stock fuel pump. I'd also stick with the name brand kits. I see alot of no name junk on Ebay for cheap. You don't know what you are getting with no name products. You don't need a dyno tune. Follow the instructions and everything will be fine. Nitrous kits are very conservative out of the box. Where you run into problems is when soleniods start sticking open or closed or when you start playing with jetting, fuel pressure or timing.
Old July 9th, 2008, 10:47 PM   #17
1BADSTANG's Avatar
so why would i get a dry over a wet though? Would it not be cheaper and easier to just spend the 900 bucks at brenspeed and get the purge, bottle heater, window switch, pressure gauge, and nitrous kit for the whole wet kit?
Old July 9th, 2008, 11:02 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Depends on what kind of wet kit it is. Got a link?
Old July 9th, 2008, 11:06 PM   #19
1BADSTANG's Avatar
Brenspeed…ZEX MUSTANG 5.0 NITROUS SYSTEM
Old July 9th, 2008, 11:07 PM   #20
1BADSTANG's Avatar
all the parts like window switch pressure gauge are in the nitrous section of the 05+
Threads Similar to: 125 shot nitrous
Biggest nitrous shot SilverStang03 99-04 26 April 27th, 2008 12:43 AM
125 Shot? SantanielloITA V6 Mustangs 25 November 10th, 2007 02:56 PM
What Shot of Nitrous Do You Use? crappy_head 99-04 3 September 14th, 2007 10:45 AM
stage 2 cams and 125 shot garydahl General Tech 10 August 16th, 2007 02:38 PM
max nitrous shot TKE493 99-04 6 April 26th, 2007 10:35 AM
