Discussing Need smart people to help figure out my problem!! in the 5.0 Mustangs Forum. I may be wrong about the spout, but I still dont think that is it. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
1989 lx convertible
10.87 @ 128 ( old 302 combo)
I may be wrong about the spout, but I still dont think that is it. I would look into the pcm connectors, and also check ALL of the grounds. A missing/bad ground has f!@#$d me up many times, doing crazy stuff.
383w in the vert now baby!!!! |
#22 | |
1991 Mustang GT
Also i have replaced the PCM, redone every ground, and done a wire integrity check on all the inportant wires... It appears to check out.. |
#23 |
don't listen to all these neg comment's lol i had the same problem plauge me for a long time put a msd box in and check your plug gap and i bet my car your problem will be solved
btw you really don't want my car cause i just blew the motor lol
518.9 Wheel HP!!!!! 491 Torque!!!!!!!! |
#24 | |
1991 Mustang GT
#25 |
1991 Mustang GT
Yeah a MSD box is definately in my near future! Did that fix your problem on your car, before it blew?
#26 |
83 Mustang GT-Twin Turbo
10.82@126
Have you changed the TFI module on the side of the distributor? That will also Cause the problem you are have. It will tell the computer that rpms are different in it will drop timing and injector pulse( like a rev limiter). If you have a buddy with another 5.0 borrow theirs and see what it does. And def. check that all the grounds are good. Also the ground connector by the battery. It will get corroded. It is the black ground connector that almost looks like a fuse holder It can also cause a similar problem. Its one of the main computer ground for loop. Hope you figure out and one of us helps you out!!
BOOST!!! The replacement for displacement!!
#27 |
i changed my tfi module 3 times and still no change wen't through every sensor......no change still the same prob until i put the msd in no rev limit problem @ 5200
it wen't all the way up prob why i blew my motor........lol
#28 |
1991 Mustang GT
I have also changed the tfi a couple of times with no luck, also redone and cleaned every ground on the car.. Thanks alot for everyone's input though.. I think before i do anything else i should get an ignition box for it...
#29 |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
I don't see what an ignition box is going to do for you. If that fixes the problem then it is just masking a problem that is elsewhere. I've gone high 10s with the stock TFI ignition. The TFI ignition is a good set up from the factory.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#30 |
You say it works fine with the spout out and set at 32 degrees. I would say it's over advancing with spout engaged. Therefore try setting base timing to 10 or even 8 and take a ride. If that doesn't fix it, have you tried another dist. pickup or new dist?
BadShoe Productions, How-To-DVD's specializing in Ford drivetrains www.BadShoeProductions.com |
#31 |
1991 Mustang GT
I have had the timing from 0-20 and the problem is still there it just changes what rpm it starts to miss.. I have tried 3 new distributors... With the timing locked @ 32*, and the spout removed it will rev to 6k in neutral, but still won't pull much past 5k under load... Also it isn't throwing any codes that would affect this and the computer is new.. But the spark plugs look completely clean?? They have about 4,000 miles on them and still look like they did when i pulled them out of the box? It looks to me like it isn't getting enough fuel, but it isn't throwing a lean code? Also i have replaced all the fuel components except injectors.. The wierd thing to me is that it misses at the exact same rpm every time when the computer is controlling timing advance?
Thanks, Richard |
#32 |
1991 Mustang GT
I know that the tfi is a pretty good system, but i think mine is faulty. Would the MSD box bypass anything that could be causing my problem?
#33 |
IM telling you i had the friggin same problem
pain in the ass MUSTANGS!!!!! I changed everything 2 or more times im talking distributers tfi's wires coils and nothing seemed to help put the msd in and it was fine!!!!!!! who cares if it maskes the problem as long as it fixes it lol!!!!!!!!!!!!!!!!1
#34 |
I think you said your using a 70mm MAF from a SN95. If your still using a 90-93 PCM, it's not reading that MAF the same as an earlier unit. This mismatch could be causing a lean or rich high rpm and it's unlikely to flag a code because it's in open loop at WOT. If you have a stock MAF for the correct year car/PCM might be worth a try.
#35 | |
1991 Mustang GT
#36 |
Don't know if this was suggested, but I would check air/fuel ratio with a wideband.
#37 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
#38 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
#39 |
1991 Mustang GT
#40 |
just for shits and giggles check all your grounds i know someone mentioned it already but when i ripped down my motor tonight i found a really loose ground on the back of the header
i know darrell say i told you so prob was my problem and when i put the msd in i grounded it so the ignition system was good than who knows can't test it cause i got a broken ass motor lol really worth a try
Threads Similar to: Need smart people to help figure out my problem!!
| is this smart? | RC00GT | 99-04 | 5 | June 17th, 2008 09:20 AM |
| Get Smart | homebrewed | The Clubhouse | 10 | May 24th, 2008 09:53 AM |
| Smart Computer People Needed | yojoe600 | The Clubhouse | 29 | November 24th, 2007 09:56 PM |
| a test for all you smart people | HMUSN | The Clubhouse | 12 | June 30th, 2007 12:56 PM |
| Trying to figure out this problem | Plays With Squirrels | 96-98 | 4 | January 10th, 2007 12:07 AM |
