H pipe Hanger
Old July 9th, 2008, 05:04 PM   #1
88' Coupe & 92' HB
Caddpro is on a distinguished road
H pipe Hanger
Anyone know where I can get the hanger for the h pipe that goes between the crossmember and transmission? I have checked all the local salvage yards and came up empty. And the local parts stores all look at me like I am crazy and say to go to the dealership. Dealership says they can get me one, but it is ~$100.
I need a sig....
http://www.caddpro.net/mustang
Old July 9th, 2008, 05:45 PM   #2
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Mine was $70 from a Ford Dealer.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old July 9th, 2008, 06:44 PM   #3
Hunt_chevs's Avatar
2002 Gt
Not Slow
make one,. you can find very similar material at an ace hardware or home depot. Friend of mine actually used re-bar...
Old July 9th, 2008, 06:58 PM   #4
1983 mustang lx
83fox is on a distinguished road
just use some steel rod, like a steel dowel, bend it (use a torch if avalible) and then weld it on your exhaust.
Old July 9th, 2008, 07:04 PM   #5
88' Coupe & 92' HB
I found one for $48 plus shipping >>> 79-93 HANGER, H-PIPE, MANUAL MUSTANG
Thanks for the replies. I did think about making one, but I would rather have one as a go by. I may hold off a little longer and see it the local muffler shop can fab up something. I talked to the guy there earlier and he said to bring it by and he would see what he could do. I hate to drive it around with the entire exhaust system hanging from the headers. I have only went 4 miles on my fresh rebuild and it is killing me.
I need a sig....
Old July 9th, 2008, 07:17 PM   #6
Hunt_chevs's Avatar
2002 Gt
Not Slow
any halfway compitent muffler shop can do this for minimal dollars
Old July 9th, 2008, 08:21 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Look at the dump. I've thrown out at least 100 of them.....
Old July 9th, 2008, 09:59 PM   #8
The Razor's Edge
White Thunder's Avatar
yeah i would say a muffler shop
founder of the FTN Club
Old July 9th, 2008, 10:13 PM   #9
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i toss mine too, you don't need it
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 9th, 2008, 10:18 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I use to go thru so many transmissions that I found getting rid of that bracket allows you to pull the H-pipe down to remove the trans without dropping the exhaust.
Old July 9th, 2008, 10:49 PM   #11
86_Notch's Avatar
1986 lx notch
9.98 @ 135
keep it simple, if you absolutely don't need something then get rid of it, the less stuff you have the less stuff to break or aggrevate you
Old July 9th, 2008, 11:04 PM   #12
91cobra5.0's Avatar
98 Cobra
i just used a regular hanger, like one you would use for hanging the pipes at the end. i got ones that fit really tight into the rubber holes and then kind of angled them so that it wouldnt pull out so easy..... and unless you are running with your headers or exhaust manifolds with only 1 loose bolt and they are singing you shouldt have a problem with support of them coming loose and sliding out
Threads Similar to: H pipe Hanger
upper exhaust hanger lilmarc1988 99-04 11 March 6th, 2008 06:57 AM
Exhaust Hanger Help modded232 General Tech 4 February 22nd, 2008 08:35 PM
Pypes Hanger Kit street591 V6 Mustangs 3 December 20th, 2007 09:30 PM
No H-Pipe Hanger gotboost562 5.0 Mustangs 9 September 27th, 2007 12:33 AM
